Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
l92 in c5
Old 04-11-2012, 09:03 PM
427TTA4's Avatar
Default l92 in c5
Hey fellas I need your help again I am swapping a l92 into my c5.Basically what's the easiest method to do so?? I heard of a converter box to go around the reluctor wheel swap made from someone.Last what parts ot my ls1 can be used as far as like the oil pan?? Wp?? Basically will all the front end accessories bolt right on?? Thanks
Old 04-11-2012, 11:45 PM
BLWN1's Avatar
Like to know what you find out on this...
Old 04-12-2012, 10:22 AM
liv2race's Avatar
LPE converter box, you will need to drill and tap the side of the block and relocate your knock sensors there (do a search, lots of info on here) you will also need to extend your knock sensor harness, LS2 or above throttle body and harness converter or adapter plate for your current LS1 throttle body, fuel injectors are different and you will need the converter plugs if you are running the LS3/LS7 style injectors. other than that nothing else. I am doing this right now, but with a forged LS3 (same thing basically) I am assuming you have the 58X crank and cam sensor
Quick Reply: l92 in c5
