C6 Z51 Brakes
I did the C6 Z51 mod on the front of mine with the Baer 14" rears.
The Z51 rotors are 1" larger in diameter as I recall. Do I feel a difference braking on the street...no. But, I would be willing to bet that GM must have done some testing that showed some improvement out on the track. Calipers are
the same so I wouldn't expect a huge improvement.
To me, more than anything else, it sure looks a heck of a lot better than the tiny rotors that are on our cars from the factory.
I might be inclined to check with a sponsor and see just how much the caliper relocation brackets are running now along with whatever rotor you may want to see if what you're being offered is a "deal" or not. Scoggin-Dickey has everything 10% off right now.
Rick
Rick
Thanks for the reply Rick. I've read that the abutment brackets that came stock on the car work fine.
I'm beginning to think this may not really be worth it. I was blown away at the stopping power from just the stock brakes compared to my FBody.
300 is hard to pass up... I figure I'd at least need lines though.
