Checkout our new Fan Control Switch....For the C6...
Just launched....
Take complete control of your C6, Z06, or ZR1 coolant fan with our new Corvette C6 Fan Control Switch
This brand new Plug-And-Play control module installs under the hood, at the fan connector, and is designed to manually control the PWM coolant fan found on the 2005-2009 C6, Z06 and ZR1 Corvette. When the need arises to manually cool the radiator down, this module gives you complete control (high, low, and normal) of the fan with the simple flick of a switch. This kit can be installed in less then one hour, once you decide on where you want to place the control switch. This switch matches the style and look of cockpit switches used on all the C6 Corvettes.
Comes with easy to follow installation instructions.
Ordering info below.
Jim:thumbs:
Jim:thumbs:
