Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 z06 header swap, now missing
Old 05-17-2014, 03:02 PM
Lowmiles's Avatar
Default C5 z06 header swap, now missing
Recently did the headers on my z06 and now it keeps missing from 1200-3000 rpms. I've checked all the plug wires, plugs and checked my ground to the block. Cannot for the life of me find what would cause a miss. Any suggestions?
Old 05-17-2014, 06:00 PM
ss rally red's Avatar
Is the CEL flashing during those RPM's ?
Old 05-17-2014, 11:08 PM
Lowmiles's Avatar
No, but it is throwing the p0118 code for heating issues.
Old 05-18-2014, 12:56 AM
Burken01's Avatar
Did you get a tune afterwards?
Old 05-18-2014, 10:39 AM
Lowmiles's Avatar
Not yet can't get to to run right long enough to get to a shop for the tune
Old 05-18-2014, 06:01 PM
Lowmiles's Avatar
Found one issue, the temperature sensor was bad, now it's still missing but only under a load. Could this be a tune issue?
Old 05-19-2014, 06:59 AM
Larry's Avatar
Could you have cracked a spark plug? Damaged a plug wire?
Old 05-19-2014, 11:02 AM
Lowmiles's Avatar
Went through them all they're all fine only thing I haven't done is checked my o2 readings.
Old 05-21-2014, 05:30 PM
Lowmiles's Avatar
Anybody have any clue what could cause this
Old 05-21-2014, 06:59 PM
Larry's Avatar
Did you check the plug wires with an ohm meter?
Old 05-21-2014, 07:09 PM
Lowmiles's Avatar
No but I've put 2 different sets of wires, both brand new on it, I would think they'd be fine. I can get a hold of an ohm meter to check them though.
Old 05-21-2014, 07:36 PM
Larry's Avatar
Having tried two sets of new wires I agree pretty much rules out wires.
If you had HP Tuner you could scan for misfire. It has a series of misfire PIDs that would most likely give you the source.
Old 05-21-2014, 07:48 PM
Lowmiles's Avatar
My brother has hp tuners I'll see if I can get with him this weekend to see what it does.
Quick Reply: C5 z06 header swap, now missing
