Matt@FSP+416ci+ECS SC+Alky+Big Cam Kit+Built Trans+Stage 1 Fuel = ?
It all started with a few emails to Matt@FSP. After talking and emailing back and forth I knew this was going to be epic.. Initially I just wanted a supercharger and about 600whp but then after rethinking it and realizing I may never get this chance again, it was a no brainer.. Go hard or go home!
Matt and I communicated almost daily via text and the mod list grew... I cant say enough how awesome Matt has been and how he never once complained or showed any type of negative vibes after a few hundred texts lol. Pretty easy going guy and I recommend anyone in the FL area and within 50 states fly/ship their car to FSP. Well, people already drive from TX to have him tune their car so if you are in doubt just make the drive its worth it.
This isnt my first time in the FI game but it damn sure feels good to be back! So here we go, dropped the Vette off and after a few weeks got back a monster.. The HULK pretty much..
Resulted in 711whp!!
List of mods installed by FSP:
ECS SC
ALKY kit
ECS Stage 1
Big Cam .624 lift and 240 deg duration
Brian Tooley Drivetrain kit
Trunion kit
Trans LVL IV Phoenix
PATC Torque Converter 2800 Stall
Alternator 270 amp
Trans Cooler
Kooks Headers
Kooks X pipe
ATI Dampener
Dash Logic
PLX DM6 SM AFR2 Sensor Kit Combo
UPDATE TO BUILD,
416ci, 10:1 Compression Ratio, Estimated 950HP Motor Rating: 1200HP
CP Pistons - Complete Piston Set Including Rings, 4.070" Bore, 4.000" Stroke
Manley H-Beam Connecting Rods
Manley 4.000" Stroke Pro Series Crankshaft
Clevite MS2199 Main Bearings Clevite Rod Bearings
Melling Select High Volume Oil Pump, LSx Katech C5R Timing Chain
ARP 04 Chevy LS1 Pro-Series 12pt Head Stud Kit
GM Oil Pan Gasket, LSx Wet Sump
GM Balancer Bolt, All LSx Wet Sump GM Rear Main Seal, LSx
GM Rear Timing Cover Gasket, All LSx GM Front Timing Cover, Seal, All LSx GM Front Timing Cover, Gasket, All LSx GM Exhaust Manifold Gasket, All LSx GM Waterpump Gasket, All LSx
GM LS9 Head Gasket (Single)
GM LS7 Lifter Set
Fountain Race Engines - Machine Work
Align Hone Mains, Check Big & Little Ends Connecting Rods, Check & Set Main/Rod Bearing Clearance, File-Fit Piston Ring Set, Assemble Pistons to Connecting Rods, Weigh Rotating Assembly, Balance Crankshaft, Assemble Rotating Assembly, Assemble Top End Package - Including Degree Camshaft, Timing Chain, Oil Pump, 2x Cylinder Heads
FSP Contact Info:
Florida Speed & Power
EFI Tuning Concepts LLC.
6224 31St St East
Suite 4
Bradenton FL 34203
941-756-RACE (7223)
Matt Sorian, Member: matt@floridaspeedandpower.com
Rodney Whittaker, Member: rodney@floridaspeedandpower.com
ECS SC
ALKY kit
ECS Stage 1
Trunion kit
Alternator 270 amp
Trans Cooler
Kooks Headers
Kooks X pipe
ATI Dampener
Dash Logic
UPDATE TO BUILD,
GM LS7 Lifter Set
FSP Contact Info:
6224 31St St East
Suite 4
Bradenton FL 34203
941-756-RACE (7223)
Ah that doesnt matter much dont put too much weight into that bs. My 50k miles are a lot less abuse than some who have 10k miles. Id go with my heart and build the Vette I really wanted and not be worrying about that but thats my opinion.
416ci Spec Build Sheet
GM LS7 Lifter Set
GM LS7 Lifter Set
