Stainless Steel Headers Made In USA for Your C5 Under $1000 @ Hinson Motorsports
HINSON Motorsports is proud to offer the only ceramic coated stainless steel header built in the America under $1,000. The HINSON Motorsports C5 header systems are proudly built in the USA from stainless steel and then ceramic coated for lower under hood temperatures. Our ceramic coated stainless steel headers use mandrel bent 1 7/8" tubing and 3/8" flanges for a precision fit and finish. These headers slide in to place without the need to loosen the engine mounts or the front crossmember. Installation time is short and can be done easily from below the car.
Features
Stainless Steel Construction and High Temp Ceramic Coating
Easy installation for both wet and dry sump applications
1 7/8" Mandrel Bent Tubing for peak exhaust flow
3" Collectors
Lower under hood temperatures than non-ceramic coated headers
Slip fit collector for easy connection to a performance X-pipe
Ceramic Coated X-pipe for reduced center console temperatures
Direct fit application - No fabrication required.
Includes O2 Extensions ($50 value)
Includes
Ceramic Coated Stainless Steel Headers
Ceramic Coated Stainless Steel Header Extensions
Ceramic Coated Stainless Steel X-pipe
Stainless steel rear axle back connection pipes
O2 Sensor Wire Extensions (x2) $50 value
Clamps
Ceramic Coated X-Pipes for reduced interior temperatures
Installed prior to ceramic coating
In stock and currently being ceramic coated. Anticipated ship date of July 27 2015.
