Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
06 6sp Trans hiccup
Old 10-25-2015, 02:39 PM
GreatWhiteZ28's Avatar
Default 06 6sp Trans hiccup
Tried a search and didn't find what I was looking for really as it was all related to an Automatic. But here's the hiccup I had yesterday, drove the car to work yesterday AM without any problems, when i got off and started it up, it wouldn't go into gear, it was stuck in neutral, Now with the Clutch pedal fully pressed when I tried to put it in any gear it would start to roll fwd or backwards if in reverse. after a min and pumping the clutch pedal a handful of times, I shut it off and it went right into gear. So I started it then, it kinda jerked a bit like it wasn't fully in gear.. I got it home and replaced the clutch master cylinder fluid per Rangers method as it was on my agenda anyways... So far it has not done it again.. Does this sound like a Master Cylinder issue?? Feels a little tougher to shift at times, but that part could just be in my head
Quick Reply: 06 6sp Trans hiccup
