C5 Corvette Trap Door Oil Pan Baffling Inserts
LS1Tech Sponsor
We now have trap door oil pan baffling inserts available for the two-piece C5 Corvette "batwing" oil pan.
These inserts snap right into the factory pan and are very easy to install, requiring only the removal of the bottom oil pan access panel.
Adding these trap doors around the pickup significantly reduces oil starvation. These can typically handle up to 1.4 G's without any loss in oil pressure.
Note this kit will not work with the earlier single-piece C5 Corvette oil pans.
Check it out here: http://www.improvedracing.com/oil-pa...pan-p-743.html
