Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What's the ring gear size on a C5?
Old 11-13-2001, 07:17 PM
Coal Mining Director
onfire's Avatar
Default What's the ring gear size on a C5?
We know the fbod is a weak 7.625 inch ring gear but I've never seen a dimension posted on the C5...they don't seem to break as easily so it must be stronger.
Old 11-13-2001, 07:39 PM
c4c5specialist's Avatar
Default Re: What's the ring gear size on a C5?
Hi there,
The size is 7.625 ring gear.
It is also rated at 550 ft lbs of torque.
Besttoyou, c4c5
Old 11-13-2001, 07:40 PM
cendres's Avatar
Aha. I thought they were an oddball size. The only way to get a gear deeper than 3.42 is to buy the 3.73 Getrag setup. c4/c5, do you know why that is?
There is no way I will pay $1600 (best price I've seen lately) for 3.73's. Sucks. <img src="images/icons/frown.gif" border="0">
[ November 13, 2001: Message edited by: cendres ]</p>
Old 11-13-2001, 07:45 PM
AgaveCorvette's Avatar
[quote]Originally posted by cendres:
<strong>I think it is an oddball size. The only way to get a gear deeper than 3.42 is to buy the 3.73 Getrag setup. Would you pay $1600 (best price I've seen lately) for 3.73's? Sucks. <img src="images/icons/frown.gif" border="0"> </strong><hr></blockquote>
True. Motive is rumored to have 3.90 and 4.10s coming, but there is no part number, yet.
Old 11-13-2001, 07:48 PM
66ImpalaLT1's Avatar
Actually there is a part number:
[code]
PART # TEETH RATIO
V885342L 41-12 3.42
V885373L 41-11 3.73
V885390L 39-10 3.90
V885410L 41-10 4.10
</pre><hr></blockquote>
See page 30 of this pdf:
http://www.midwesttruck.com/sitecata...ffCat_2001.pdf
Eric
Old 11-13-2001, 08:03 PM
woah, cool. <img src="images/icons/smile.gif" border="0">
But they aren't shipping them yet, are they?
I dont think so.
Old 11-13-2001, 08:11 PM
Scalpel's Avatar
How will this work, the Motive ring and pinion? It was my understanding that the tools and data required to change the ring and pinion in a C5 Differential required a very expensive set of tools from Kent Moore and their instructions. Also, it was very very tedious. Someone fill me in on this. I would LOVE 4.10's!
Thanks fellas. <img src="images/icons/smile.gif" border="0">
Old 11-13-2001, 08:20 PM
[quote]Originally posted by NastyC5:
<strong>How will this work, the Motive ring and pinion? It was my understanding that the tools and data required to change the ring and pinion in a C5 Differential required a very expensive set of tools from Kent Moore and their instructions. Also, it was very very tedious. Someone fill me in on this. I would LOVE 4.10's!
Thanks fellas. <img src="images/icons/smile.gif" border="0"> </strong><hr></blockquote>
yes. They require a special Kent Moore tool set. If you're interested in doing a swap, check out GM TSB #01-04-20-001. It lists procedures, required tools, data, and illustrations on setting up the Getrag C5 diff.
Old 11-13-2001, 08:21 PM
P.S., when the Motive gears become available, I will be doing gear swaps for people. I'll let you know details as soon as I see a set of gears. <img src="images/icons/smile.gif" border="0">
Old 11-13-2001, 08:30 PM
Scalpel's Avatar
Agave, thanks for the replies. Your deposition of the process when it comes time would be GREAT! I'd love to put a set of 4.10's in. My brother's '00 WS6 has a set, same bolt ons as me and he pulls me like a ****! Gotta' get even <img src="images/icons/grin.gif" border="0"> . Any idea on expected arrival date? BTW, can you send me the full TSB or tell me where I can access it? Thanks.
Old 11-13-2001, 09:03 PM
<strong>Agave, thanks for the replies. Your deposition of the process when it comes time would be GREAT! I'd love to put a set of 4.10's in. My brother's '00 WS6 has a set, same bolt ons as me and he pulls me like a ****! Gotta' get even <img src="images/icons/grin.gif" border="0"> . Any idea on expected arrival date? BTW, can you send me the full TSB or tell me where I can access it? Thanks.</strong><hr></blockquote>
I have the TSB en route for myself. I will share it with the rest of the board upon arrival.
Old 11-13-2001, 09:07 PM
By the way, whenever your brother says something about his 4.10's, remind him how much better our rear diff is than the Fbody's. <img src="images/icons/grin.gif" border="0"> <img src="images/icons/grin.gif" border="0"> <img src="images/icons/grin.gif" border="0"> Ours can actually handle more than 375 ft/lbs! <img src="images/icons/grin.gif" border="0">
Old 11-13-2001, 09:17 PM
Scalpel's Avatar
Sweet, great deal on the TSB. Oh, I don't worry about my brother much. I still kick his *** at the track, he don't have da' driving skill's his older bro has! <img src="images/icons/wink.gif" border="0"> But yes, he's always scared he's gonna break his rearend, us C5-er's don't have that problem (unless you hit ~550 ft/lbs ) <img src="images/icons/grin.gif" border="0">
[ November 13, 2001: Message edited by: NastyC5 ]</p>
Old 11-13-2001, 10:39 PM
onfire's Avatar
Thanks for the info...550ft/lbs...I'm envious...Nastyc5 I've got a good friend in Pikeville that has a 2000 white C5 that I help mod...beautiful car...6spd.
Old 11-14-2001, 04:49 AM
HI there,
When working with Getrag during training, they stated to us that the reason why they did NOT offer gears above and beyond the 3.73 was due to the fact that cutting that many teeth into the ring seriously degraded rated torque capacity.
Why that is might be due to the actual carrier design, which limits depth of the actual ring, so that there is not enought metal behind it to support the teeth.
Also, as a sidebar to this, GM recinded all instructions on overhaul of a c5 rear axle, due to the fact that side bearing preload could not be effectively duplicated. The reason being that there is a jig, by which actual side preload is measured. This jig costs GM about $1200 each, and felt that they did not want to pay that cost.
I really dont understand why, however, unless it is seal related, side covers, front inner and outer seals. We are told not to overhaul?????
I wish I knew why this was, however, in this service area, this is how GM stands.
I think that it is screwed up, but, this is just what Getrag tells us.
Besttoall, c4c5
Old 11-14-2001, 06:58 AM
cendres's Avatar
c4c5,
Thanks for the insight!
Chris
Old 11-14-2001, 11:57 AM
Scalpel's Avatar
Thanks, c4c5specialist!
Old 11-14-2001, 11:59 AM
thanks for the input c4c5. Looks like I'll be spending some $$$ if I want to setup gears for people. :-/
Old 11-14-2001, 01:45 PM
[quote]Originally posted by c4c5specialist:
<strong>When working with Getrag during training, they stated to us that the reason why they did NOT offer gears above and beyond the 3.73 was due to the fact that cutting that many teeth into the ring seriously degraded rated torque capacity.
According to the preliminary numbers in Motive's catalog (the ones I posted above) they wouldnt have any more teeth on the ring gear than the 3.42 or 3.73's. They would have to figure out a way to make a 10 tooth pinion gear.
I guess we'll just have to wait and see.
Quick Reply: What's the ring gear size on a C5?
