What kind of power will this cam make in a stock 2002 Corvette? - LS1TECH
Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Thread Tools Search this Thread
Old 09-21-2005, 09:27 AM   #1
Default What kind of power will this cam make in a stock 2002 Corvette?
CAM 224/228 .581/.588 112
The only mod to the car will be the cam, springs, and pushrods...
Thanks
SilverSSGabe is offline   Reply With Quote
Old 09-21-2005, 11:55 AM   #2
baldurann's Avatar
Probably right around 15-20whp. You need a full exhaust and an intake, along with a tune, to see good gains with that cam (or most cams, for that matter).
At least your car will lope a little bit.
baldurann is offline   Reply With Quote
Old 09-21-2005, 11:58 AM   #3
slt200mph's Avatar
Yes.. I agree with that..you will need to get some long tube headers and good exhaust to make the most of a cam swap..I'd say 20 HP... maybe a little more but not much without exhaust mods...he has an 2002 car so it has the Z06 intake on it already
slt200mph is offline   Reply With Quote
Old 09-21-2005, 12:23 PM   #4
Quote:
If I got headers, and exhaust then how much would I gain.
Old 09-21-2005, 08:36 PM   #5
fastbasser's Avatar
I had the Comp 224/.581 on 114 and dynoed 365 with headers and cats. (A4)
fastbasser is offline   Reply With Quote
Old 09-21-2005, 10:41 PM   #6
2001 ZO6 TTP 224/224 114lsa Cam Pkg 396rwhp 380 rwtq, dual crane valvesprings, Halltech Tunnel Ram, FLP headers, ASP 25% Pully, 3.73 Getrag Rear,2004 Z06 shocks,Shaner S2 TB,Hurst
JBsC5 is offline   Reply With Quote
Old 09-21-2005, 11:21 PM   #7
Quote:
Nice Numbers
Old 09-21-2005, 11:32 PM   #8
BadMonkey's Avatar
I would say around 345-355 range with nothing more then teh cam swap and a tune. With Headers around 360-370 and with heads cam headers and cat back maybe around 380 or so. I had a 99 A4 with a 222/222 581/581 114LSA cam with TPIS headers, Custom heads, ASP Pulley, stock cats, corsa catback and a 3200 VIG stall with 3.15 gears that would not lock on the dyno. It made 388RWHP.
BadMonkey is offline   Reply With Quote
Old 09-22-2005, 12:01 AM   #9
baldurann's Avatar
I'd guestimate right around 385whp.
Old 09-22-2005, 04:38 PM   #10
On my 02 Z06 with Long Tubes, Varam intake, B&B Cat Back and a 228/232 581/592 112 LSA cam I put 415 to the tire. This was on a very conservative tune with 91 octane.
RB185AFM is offline   Reply With Quote
Old 09-22-2005, 09:06 PM   #11
platinum's Avatar
what about 224/228 581/588 115 lsa. what kind of power gain on a ls6 with a maggie compared to stock cam with maggie
platinum is offline   Reply With Quote
Old 09-22-2005, 10:24 PM   #12
Next post
David Gordon is offline   Reply With Quote
Old 09-22-2005, 10:26 PM   #13
I made 414 with a set of TEA 1.5s and a smaller 224/224 581 112ls cam. It was very drivable and had good power down low.
Old 09-23-2005, 11:20 AM   #14
Quote:
Good numbers
Old 09-23-2005, 03:19 PM   #15
BlueSix's Avatar
Thanks
Probably about 335 rwhp through the stock exhaust. Will some more bolt on's (some form of CAI, full exhaust, ported TB, pulley) you could see around 390 rwhp if you're a 6 speed.
BlueSix is offline   Reply With Quote
Old 09-23-2005, 08:57 PM   #16
99FRCTorchRed's Avatar
With that cam about 30 hp but you will need a tune.....I wish I went with a bigger cam......... cam made a big difference from when it was stock.
99FRCTorchRed is offline   Reply With Quote
Old 09-24-2005, 01:15 AM   #17
I put that same cam in my Z06 a couple of years back.
I already had all bolt-on mods, it produced 36 rwhp.
Here's the dyno sheet before 376, w/cam 412.
http://www.c5frc.com/photogallery/Dyno/Dyno%208.jpg
FRC Tom is offline   Reply With Quote
Old 09-24-2005, 02:04 PM   #18
Kraest's Avatar
I made 412 in a C5 Coupe (not Z06) with a cam + bolt-ons.
Mike
Kraest is offline   Reply With Quote
Old 09-24-2005, 11:23 PM   #19
Joe G's Avatar
My cam is close - with inexpensive heads and headers,
404 HP, 382 TQ
Details here:
Patriot Heads/Cam Dyno Results by Horsepower Sales/Next Level Performance
Joe G is offline   Reply With Quote
Tags
cam, exhaust, frc, heads, make, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
