Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Head Swap
Old 06-15-2006, 12:37 AM
c5_ls1_6spd's Avatar
Default Head Swap
when everyone did their head swap, did you all use ARP heads studs/bolts? or used factory head bolts?
Old 06-15-2006, 10:52 AM
Kraest's Avatar
ARP, although they are quite pricey at around $200 for the set.
Old 06-15-2006, 06:16 PM
Sigforty's Avatar
ARP here!!
Old 06-16-2006, 10:30 AM
WKMCD's Avatar
ARP on mine.
Old 06-16-2006, 12:16 PM
allngn_c5's Avatar
ARP all day...
Old 06-16-2006, 12:18 PM
Termin8r27's Avatar
I've done both, but a good idea to do ARP and forgetaboutit!
Old 06-16-2006, 12:23 PM
'02 SLP#686's Avatar
ARP - got them for $160 (bolts)
Old 06-18-2006, 12:48 AM
jbusmc1986's Avatar
I am about to do the swap and ARP bolts
Old 06-18-2006, 05:18 PM
pdd
pdd's Avatar
ive done both. stock bolts work fine but you have to clean the bolt holes each time. i went with ARP bolts and never looked back
Old 06-18-2006, 05:21 PM
cantdrv65's Avatar
Post
ARP studs wouldnt do it any other way......
Old 06-18-2006, 06:43 PM
MICAH HERRON's Avatar
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
If you are only going to swap heads and do it just once, OEM replacements are fine, but the ARP bolts are a great investments if you plan on removing them often.
Micah
Old 06-23-2006, 09:08 AM
would it be ok to reuse my old head bolts? can i reuse my old head bolts?
Old 06-23-2006, 09:13 AM
V-seriesTech's Avatar
NO NO NO.
Can't re-use torque to yeild bolts.
Quick Reply: Head Swap
