Just got my Vette, need help on major mods
I had a GTO which i owed waaaaaaaayyyyyyyyy more than it was worth. my life changed and i dont need the back seat anymore (bought a escalade). I decided i wanted a vette. my only option was a extreme high mileage vette that would allow me to carry over the 6K from the GTO.
I bought a 2002 Black Corvette, A4, and im pretty damn sure its got 3.42's or 3.15's cause it will completly fry the tires from a dead stop and its revs are about 1400 and 50mph in overdrive
it has 180,000 miles, but runs strong, no oil blow by, runs better than some of the 30 and 40 thousand mile cars i test drove. great oil pressure
I have the following already:
Stage 3 LS6 heads
Fast 90mm inake and 90mm TB
Magicstick 4 cam
I plan on doing:
402/408 shortblock
new tranny or rebuilt
new rear diff.
stall convertor
my question is, where can i get a good A4??, will the stock diff. hold up for awhile under that power?? if not what stage should i go for the diff?? i was thinking about the DTE stage 2 diff.
any other suggestions/concerns feel free to let me know, im used to f-bodys and new to corvettes so any help would be greatly appreciated.
Stage 3 LS6 heads
Magicstick 4 cam
I plan on doing:
402/408 shortblock
new rear diff.
stall convertor
example: 2700=2.73's, 3100=3.15's, 3400=3.42's, etc.
Stage 3 LS6 heads
Magicstick 4 cam
I plan on doing:
402/408 shortblock
new rear diff.
stall convertor
Stage 3 LS6 heads
Magicstick 4 cam
I plan on doing:
402/408 shortblock
new rear diff.
stall convertor
For the auto...I belive there is alot of comapnies out there....someone i'm sure will recommend someone.
...as for the DTE II rearend...they are good....but, IF you can, swing for the stage III. I've seen my cousin snap several modified rearends...and is now on the stage III. Granetd...he's makeing crazy power but...you get the idea.
I'd also get the DTE strut brace. Great mod...inexpensive.
J
1 Post
I am running the DTE stg III with the Brace. Very good combo. You can get your tranny rebuilt with all the goodies. Your car will be bullet proof. How's the suspension with all those miles? Good luck. Let us know. BTW that rear end can take some abuse, hardened output shafts on both sides, micro polishing, cryo treated gears, etc, etc, etc. Shop around before you buy one. I saw a range in price of about 2899 to 4199. Some shops. Call Bobby at LG Motorsports and I am sure he can hook you up if you tell him Doug sent ya.
