Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
best mods for a C5 Z06
Old 07-11-2006, 01:02 PM
CamaroSS621's Avatar
Default best mods for a C5 Z06
ive had my Z for about 2 months now and im already getting the itch. I do not want to go overkill again like I did on my SS, I want to keep it mostly stock or at least always be able to put it back to stock over a weekend. Give me some ideas. Does a tune really add that much power?
Old 07-11-2006, 01:42 PM
AOC
AOC's Avatar
1. VaraRam
2. LT headers and X-Pipe
3. Tune
4. DRs
If you get the tuning right, you should have 390+ rwhp.
Old 07-11-2006, 02:20 PM
vararam would be the intake I would do, do you think a hand held tuner is good enough, or a dyno tune be better?
Old 07-11-2006, 02:31 PM
AOC
AOC's Avatar
Personally, if you have a laptop, I'd get LS1edit. If not get a dyno tune.
Old 07-11-2006, 02:46 PM
Checkmate's Avatar
No, ls1edit sucks.
Get hptuners or efilive.
Old 07-11-2006, 03:02 PM
ttp or rapid would most likely be doing my tune. I know matt very well and have had many friends use mikey at rapid. How about some juice on the stock ls6 motor? I heard 100shot is perfect.
Old 07-11-2006, 04:58 PM
AlexLs1's Avatar
Originally Posted by Checkmate
No, ls1edit sucks.
Vice versa.
I had a hypertech, just wasted my money, the only way to tune any LSx Engine, is with an Edit tune. You have to know how to use it, otherwise it kinda of defeating the purpose.
My Hypertech I had, was bought to turn the engine light off due to the fact that I didnt have cats, and the o2 sensors weren't reading anything. On the Dyno it didnt do anything. With an Edit tune alot of performance shops can point you in the right direction of getting one, and do the tuning for you.
Over time with the Hy[ertech tune, apart from it not turning the "Service Engine Soon" Light off, it made the car jerk, and it would only accelerate hard if you were above 3000rpms. I got an Ls1 Edit tune and not only did it fix, all my problems (jerking, and such) I gained 25rwhp, and over 40flbs at the wheels from the first pull. The final #'s were 330/ 340.
This is just my opinion, but I had nothing but trouble with a Hypertech tuner.
Old 07-11-2006, 05:43 PM
with just the intake and tune, what do you think Id put down? btw: just ordered a vararam intake
Old 07-11-2006, 06:54 PM
V-seriesTech's Avatar
1. VaraRam
3. Tune
4. DRs
True.
Old 07-11-2006, 07:25 PM
Checkmate's Avatar
Originally Posted by AlexLs1
Vice versa.
Have you ever used HPTuners? Take a visit to the PCM tuning forum on this site. There are many very happy HPtuner customers, including me. Ask what they prefer in that forum.
Old 07-11-2006, 07:57 PM
jbusmc1986's Avatar
probably about 410/390
Old 07-12-2006, 10:06 AM
huckzilla's Avatar
edited...misread the post
Old 07-12-2006, 10:57 AM
ROJO99's Avatar
1. VaraRam
3. Tune
4. DRs
Ditto...
Old 07-13-2006, 11:12 PM
madradvette00's Avatar
twin turbo
Old 07-14-2006, 10:25 AM
jbusmc1986's Avatar
Originally Posted by madradvette00
twin turbo
Absolutely
On a more serious note though... ebay lt's, off road x, BIG CAM, ud pulley, zip tie mod, and a tune.... you will be very happy and be making somewhere around 420 ish, maybe more
Old 07-14-2006, 11:07 AM
2scoot's Avatar
A tuner is the last thing you need to worry about until you do some motor work.
I would start with a good CAI, like Halltec then add in a set of LT's & X pipe and then a cam. Then find a reputable tuner to take care of the computer work. You'll be well over 400 at the wheels if you do your homework.
Old 07-14-2006, 12:21 PM
Originally Posted by jbusmc1986
Absolutely
zip tie mod?
Old 07-14-2006, 01:30 PM
MICAH HERRON's Avatar
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
Originally Posted by CamaroSS621
zip tie mod?
You have a vararam coming, don't even worry about this mod. LT Headers is a great power adder and it will give you some serious torq too.
I think that one of the best tune programs is the EFILive, the HP Tuners is fine, but I have seen less issues with EFILive between the two. I think this is something you will not need to worry about for a little while. Do the exhaust and CAI and look for a decent cam and then worry about tuning. The cam and LTs will put you into the 400s easy!
Old 07-14-2006, 10:49 PM
zo6vetteman2003's Avatar
I've done almost everything up top except for an electric water pump and underdrive pulleys. I need a new dyno on this new clutch. The stock ZO6 clutch couldn't hold past the torque peak, so I bought the SPEC Stage 3+ and can put the power down finally. I made 440+rwhp @ only 5000rpm on slipping clutch. At 7000rpm hopefully should make another 20rwhp.
Old 07-15-2006, 12:13 AM
DoesSpeedTurnUon's Avatar
I just bought SW LT's and Random Tech X pipe, can't wait to get it on and see what i put down.
CAI is next mod. Shifter was first. 335/30/18 tires were first too!
Quick Reply: best mods for a C5 Z06
