Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What is this thing? (98 C5 underhood item)
Old 07-24-2006, 07:55 AM
mqqn's Avatar
Default What is this thing? (98 C5 underhood item)
Hi Folks -
I pulled the intake off of a friends this 98 MN6 coupe today to replace the oil pressure sending unit, and to check the vacuum hookups.
We found this little item (pictured below) on the left side rear valve cover nestled under the fuel injector harness.
Notice that the vacuum hookup (indicated by the white arrow) was taped up and was not hooked to anything.
We looked at my wifes 99 coupe and it does not have this unit, nor was it mentioned in my 2002 service manuals.
Here are the pics - if you know what it is I'd appreciate some info.
best regards -
mqqn
Old 07-24-2006, 08:19 AM
PLOEG's Avatar
good luck.
Old 07-24-2006, 08:43 AM
200MPH's Avatar
That's your EVAP purge vacuum switch. If you have a service manual its on or around page 6-1118.
Old 07-24-2006, 08:56 AM
mqqn's Avatar
Hi 200MPH -
Thanks -
So it should be plumbed into the EVAP purge solenoid?
It is not plumbed to anything on this car, and the EVAP purge solenoid is present on my 2002 Z06 and my 1999 coupe but this purge switch is not.
My 2002 Helms manuals do not show this item nor is it mentioned in the manuals (as stated in my first post).
I am perplexed as this component did have a vacuum leak on the 98 I worked on, and yet the car runs fine and did not show any codes.
I plugged the line and the car runs beautifully, but I was concerned that this componenet was lying on the side of the rocker cover and was not seeming hooked up.
I appreciate your reply (here and at CF).
best regards -
mqqn
Old 07-24-2006, 09:39 AM
200MPH's Avatar
I got a "T" fitting in between switch and solenoid on mine. I have a 98 service manual and its in there so if you need some pics just let me know.
Old 07-24-2006, 09:45 AM
mqqn's Avatar
Hi 200MPH -
Thank you - I would very much appreciate the picture showing how to hook this switch up - I just hate putting a car back together with something like this not hooked up.
Thanks for your reply - you nailed it for us!
best regards -
mqqn
Old 07-24-2006, 10:10 AM
200MPH's Avatar
What's your email address?
Old 07-24-2006, 10:21 AM
mqqn's Avatar
Hi 200MPH -
I pm'd you.
thanks!
best regards -
mqqn
Old 07-22-2010, 06:59 AM
gadgetguy's Avatar
Default I have the same question
I have a 98 Corvette and I was putting it back together after pulling the intake to change the oil pressure switch and found that 2 of the 3 ports on my evap purge switch did not have anything connected. The one you cannot see in these pictures is Teed into the pipe between the evap solenoid and wherever it goes into the firewall. I assume to the evap canister. The other 2 look exactly like in the picture. One looks like it could just be a vent but the one with the L shaped hose looks like it should go somewhere. I have the preliminary service manuals but none of the illustrations I can find in there show any detail about these 2 ports.
Thanks for any help you can provide.
Old 02-25-2018, 04:39 PM
Carmine Naccarato's Avatar
hello i noticed that i have the same thing on my 97 C5 Corvette if you dont mind id like to see those pics thank you.
Old 09-03-2020, 09:55 AM
bcampany's Avatar
Hi,
I have a 98 convertible and I'm getting gas vapor smells when in gear slowing down. I believe it is coming form this same part. Did you have any resolution with this? Mine lays beneath the fuel rail on it's side with that tube pointed towards the firewall.
Quick Reply: What is this thing? (98 C5 underhood item)
