Tire pressure sensor
It will fit the Z06 but the BCM will need to be programmed in order for the car to read the sensors. This can be done easily with a Tech 2 or at the dealer. Also make sure that when swapping sensors that you replace the o-ring. Saves a lot of headache later on when you can not find the air leak.
Chad
Chad
