Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
2008 C6 LS-3 first Cam/LG Header/ K&N dyno at LG Motorsports
Old 07-09-2007, 03:01 PM
LG Motorsports's Avatar
Default 2008 C6 LS-3 first Cam/LG Header/ K&N dyno at LG Motorsports
Hi Guys,
Here it is. This is an 08 C6 with an LG G7X-4 cam with LG Pro Long Tube Headers, K&N Air Charger, and stock performance muffler but with No tune. Computer tune to come this week.
484rwhp 440 rwtq
We did another pull after the engine was allowed to cool off and hit 488rwhp. I don't have that graph scanned in yet but I will get it up later.
This indicates that there is some heat related timing control issues just like the first dyno pulls of the original C6 Z06 before a tune.
At any rate, it looks like an easy 500 rwhp or there about with just the tune. And we are working on having a set of ported heads ready soon to install to get those numbers also.
Thanks
Lou Gigliotti LGM
Old 07-09-2007, 03:18 PM
GR33N GoblinM6's Avatar
ok so how did you get your hands on an 08 C6 LS3 already ??? and what was the BEFORE dyno's??
nevermind.. i just saw your other post below..
Old 07-09-2007, 06:05 PM
TheRooster's Avatar
Old 07-09-2007, 06:25 PM
Jeenis's Avatar
thats incredible. yall dynod my Z06 at 490 with bolt-ons, and yall got that C6 almost there. nice job!!
Old 07-10-2007, 07:49 AM
allngn_c5's Avatar
So a good set of heads should put you at 530 rwhp !! Holy smokes, who needs a 402 !!
Good job guys, and keep the updates coming.
Old 07-10-2007, 07:57 AM
allngn_c5's Avatar
Looks like a simple H/C and exhaust LS3 is going to be able to tame a tuned C6 Zo6. GM is making the Corvette better and better every year or two. LG Motorsports is leading the way in tuning and modding the LS3, can't wait to see the update once heads are installed. Keep up the good work Louis, Sean, and Mikey.
How big is the cam did you guys put into the new corvette ??
Old 07-10-2007, 08:20 AM
DocT's Avatar
Very impressive! good job setting the early standard!
Old 07-10-2007, 08:37 AM
Larry's Avatar
Lou,
How is the idle quality with the cam?
Old 07-10-2007, 09:04 AM
tjwong's Avatar
You forget that anything that can be done to an LS3 can also be done on a LS7 which has even more potential. As Lou has already shown us. But the great thing is that you can get Z performance now without buying a Z and save loads of cash!
Old 07-10-2007, 09:37 AM
allngn_c5's Avatar
No sir I didn't forget, I did forget to say it will walk a cai, tuned with headers c6 zo6. You are 100% correct though. An ls7 is able to make 630 rwhp with a big cam, head work, and all boltons, while the ls3 will probably max out at 550 rhwp (displacement limited) with same modding done. Its too early to state any concrete numbers but it is my prediction. I am sure LG Motorsports will be laying the FOUNDATION for our speculations. I expect good things in the near future.
Old 07-10-2007, 09:41 AM
allngn_c5's Avatar
The best thing about the LS3 based corvette is that you don't have to worry about the factory 500 hp rating that jacks up your insurance, and the zo6 is listed as the premium corvette which also jacks up your insurance. If I were in the market for a new corvette, I would have to strongly consider an LS3 with headers,cai, and a tune. After the warranty runs out the next stage of modding will begin.
Old 07-10-2007, 09:42 AM
allngn_c5's Avatar
Is there any information about the rear end strength of the new ls3 corvette?? Hopefully its not as weak as the c5's were. Need a good strong rear to handle all the power this motor is going to be making.
Old 07-10-2007, 10:13 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Wow, that is impressive. That is more power than a LS7 and for a lot less money.
Keith
Old 07-10-2007, 12:16 PM
chuck01's Avatar
If you really want a coupe, but want the Z06 power. This is the way to go...
Old 07-10-2007, 12:31 PM
GreenBlood's Avatar
this is freakin sweet...
Old 07-10-2007, 12:34 PM
A-Dub's Avatar
The C6 Z06 is a coupe, unlike the C5 Z06 which was a fixed roof
Old 07-10-2007, 12:52 PM
allngn_c5's Avatar
Nearly 485 rwhp and just over 440 rwtq with out having the factory tune reworked to maximize the potential of the fuel trims, timing, etc, etc. Like Lou said this car should make 500 rwhp after the tune is done and tinkered with. Like I said before this car should be able to make 550 rwhp with a good set of ported heads. The potential is scary.
Old 07-10-2007, 12:56 PM
allngn_c5's Avatar
Now for a few questions:
1. How much POWER is going to be made without having to upgrade to larger fuel injectors ??
2. How much POWER is the clutch able to withstand before it fails ??
3. How much POWER is the rearend going to be able to take without failing ??
Just asking a few questions to try and figure out what is going to need to be upgraded to compensate for all the new power the cam and boltons are adding.
Can't wait to see the numbers with the ported heads. We are all anxiously waiting.
Old 07-10-2007, 12:59 PM
allngn_c5's Avatar
How much more power do you see the G7-x5 adding vs the G7-x4 ??
Old 07-10-2007, 01:21 PM
Billdog350's Avatar
Yes, but you can't remove the roof on the C6 Z06 either.
If you want a convertable or Targa top, the modded LS3 is your best option.
Quick Reply: 2008 C6 LS-3 first Cam/LG Header/ K&N dyno at LG Motorsports
