Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
fuel gauge?
Old 08-19-2007, 03:39 PM
xrevx1's Avatar
Default fuel gauge?
Any one ever have a fuel gauge stop working? Car runs fine. Its a 99 c5 with 45000 miles on it.
Old 08-19-2007, 03:49 PM
Take 2's Avatar
Mine hanges on E if I let it get under a 1/4 a tank , and Stays down untill I fill up and then it works fine...
Old 08-19-2007, 04:17 PM
xrevx1's Avatar
Full tank in car gauge at e.
Old 08-19-2007, 06:16 PM
Take 2's Avatar
Ouch!!! Sounds like its time to Drop the Tank
Old 08-19-2007, 11:17 PM
LS1C5Vette's Avatar
Nope, this happens on a ton of vettes, if you can run your tank till near empty, add a can of seafoam to the tank and add ~8 or 9 gallons of cheveron 93, you may have to do this 2 or 3 times but it will 80% of the time fix the problem, after it goes away do this every few months as a preventive maint. I have done this and its worked for me and countless others.
Old 09-19-2007, 06:39 PM
xrevx1's Avatar
Seafoam cured the issue!! It took a few days of driving to cure after adding the can but, all is well ever since. Thanks. Glad to hear that no tank dropping was needed!
Quick Reply: fuel gauge?
