Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
spec 3+ slave shim or not?
Old 09-03-2007, 04:17 PM
slowride's Avatar
Default spec 3+ slave shim or not?
Anyone installed one lately? My old clutch let up to low to the floor so I'm hoping to avoid this by using the shim with the 3+. I have a remote bleeder so the slave will be fully blead.
After searching it seems like people like to use the adjustable master to bring the pedal up higher from the floor so I figured the shim would do almost the same thing.
Old 09-03-2007, 04:30 PM
2002camaross35th's Avatar
I installed my spec 3+ about 8 months ago and talked to shane at Thunder Racing to ask him if the Shim was necessary or could i jus leave it off and he told me that the shim was needed to keep the pedal up some...he said i might need the adjustible master but chances are that i wouldnt. Well its been 8 months and i'am having no problems with the pedel being to low..Hope this helps ya
Old 09-03-2007, 04:34 PM
mikep2002's Avatar
I installed my Spec 3+ with out the shim as specified by Spec. I have no performance issues. Works like the stock clutch.
Old 09-03-2007, 05:13 PM
slowride's Avatar
Well that narrows it down. one yes one no
Old 09-04-2007, 11:01 AM
ROJO99's Avatar
No shim and no issues to date. Installed 6 months ago...
Old 09-04-2007, 07:27 PM
slowride's Avatar
Where is the pedal engaging for you guys not using the shim. I'd prefer a few inches off the floor rather that right off the floor. I know every car is different, but corvette's are such a pain to do a clutch in you'd like to get it right the first time
Old 09-06-2007, 12:55 AM
JVetthead's Avatar
Did mine with out the shim and my pedal is real close to the floor.. guess I've gotten used to it but wish it was closer to the top.. Don't know how much the shim would raise it..
Old 09-06-2007, 06:50 AM
slowride's Avatar
Did you get the hydraulics bled completely? I know it's a pain in a vette so just asking. The old fluid could have some air in it, etc and reduce the amount of throw the system has.
Old 09-11-2007, 07:22 PM
slowride's Avatar
For the record the I installed the clutch with no shim on the slave. The pedal releases mid travel as others had stated above. Still breaking it in, but it's working fine.
Old 09-22-2007, 06:13 PM
ls1aholic's Avatar
i know its a little late, but i installed my 3+ about 6 months ago. the clutch engage a little close to the floor so i got the adjustable master. works fine now.
Quick Reply: spec 3+ slave shim or not?
