Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C6 11.42@125 on runflats!!!!!!
Old 11-12-2007, 08:47 AM
Evilways's Avatar
Default C6 11.42@125 on runflats!!!!!!
http://www.youtube.com/watch?v=NiPcvv2eyBM
timeslip here:
also ran a 11.41 @123 :
not bad for bone stock tires with several thousand miles on them
Old 11-12-2007, 03:11 PM
procsls6's Avatar
What are the mods? That is good mph, but some dr's on it and get into the 10's.
Old 11-12-2007, 03:50 PM
Evilways's Avatar
the mods are h/c ,cam,intake,headers,catback,cai and tune. The main reason I don't go out and grab some slicks or dr's is that the one weak point of the C6s is the rear. I've seen them shatter on hard hooks. Very expensive replacement and aftermarket is even moreso and still have seen them break as well. I'm done modding for now, but who knows about next year.....
Old 11-12-2007, 03:56 PM
corvetteandsilverado's Avatar
what kind of HP is the car making??
Old 11-12-2007, 04:11 PM
Evilways's Avatar
450/405 to the wheels.....
Old 11-12-2007, 04:17 PM
thats good im going to be getting a C6 soon and i want to do some things to it... hows the cars driveability? what cam and heads?
Old 11-12-2007, 04:29 PM
Evilways's Avatar
Idles like stock, maybe a little stronger. I have the GM L92 heads, GM L76 intake, a custom cam from my tuner(Carolina Auto Masters) and the grinds are his personal recipies, so I don't want to give that out. I also have LG longtube header, slp loudmouth 2 exhaust and a tune by C.A.M.(Jeff Creech). The car is a 2006 A6 and drives great, I never have to worry about overheating, the thing will pull over 1 g. to either side, and I get 29MPG on the Hwy, about 21 city, even after the mods. Everyone underestamates the GM heads, and mine are completely unported and gives me great, full rpm range power. They are a bargin as well, as I got mine, with the intake, for just under $1500.00 total.The intake has went up a little since then, but still a great deal.
Old 11-12-2007, 04:33 PM
thats amazing 21 mpg city... i was wondering about the mpg cuz my C5 is an A4 and it does good... i cant wait to get mine.. alsome car and good times at the track keep modding her!
Old 11-12-2007, 04:47 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Yet another example of how good the L92/LS3 heads are
Keith
Old 11-12-2007, 04:54 PM
Evilways's Avatar
wrap your head around this, bone stock before the break-in period was over, when I had to take it easy on the car, it showed that I got 31MPG on a 150-160mile road trip.LOL. The only thing I've found that really kills the mpg around the city is using paddle shifters. It drops to about 15mpg if I use paddles and not let it go full auto in the city.
Old 11-12-2007, 05:56 PM
i think im going with the M6 this time around i had an A4 04 GTO(hated that car) and now i have an A4 C5... i just want to change to the manual so hopefully i get even better MPG... i thought you would get worse mpg with the head cam set-up.. im surprised with the mpg you get.... i thought about modding my C5 until i can get an 08 C6 cuz i really want the LS3 but with 450 to the wheels with your mods and the money i would save buying an 06 its not a bad deal and they sound alsome!
Old 11-12-2007, 10:01 PM
SVT BAIT's Avatar
if u run DR on the car do u think the rear end will break? im getting scared im going to be doing the same mods H/C LT etc..and going to be running DR
Old 11-13-2007, 08:05 AM
Evilways's Avatar
Most of the rear breakage I've seen comes from a strong hook at the line on manual tranny C6s, but I have seen autos break as well, usually the shafts instead of the diff. On slicks, I've seen diffs shatter like glass, even with the DTE braces.If you're gonna run slicks or drs, you may want to baby it out of the hole until you get a really good feel for it and I still wouldn't do a high rpm launch. Alot of guys are doing a C5 rear conversion if they plan on doing alot of drag racing.
Old 11-13-2007, 11:50 AM
SVT BAIT's Avatar
so the C5 rear end is stonger than the C6?
Old 11-13-2007, 11:56 AM
ls1290's Avatar
Ummm..... I do not think so. I believe they are pretty much the same. The C6 only seems weaker because the C6 has more power and can break them easier.
Keith
Old 11-13-2007, 12:00 PM
ls1290's Avatar
The reason why more stuff breaks with DRs than ETs or Slicks is that the DR has a much stifffer sidewall. The softer sidewall of the ET or Slick aborbs some of the initial torque, aka sidewall wrinkle, before all the torque/power is transferred to the ground. With the DR all the initial torque is absorbed by the driveline: differential half shalfs, axles, torque tube, tramissions input/output stafts.
Keith
Old 11-13-2007, 12:41 PM
SVT BAIT's Avatar
so what does he mean by when he says the C5 convertion? how much does a strong rear run for?
Old 11-13-2007, 12:59 PM
Evilways's Avatar
The C5 and C6 rears are not the same , *exactly*...the C5 Z rears hold up to higher hp/tq launches than the stock C6 rear does, especially the 2005 C6 rear. Alot of folks are doing the swap or "conversion" to the C5 rear or at least some of the parts, such as the shafts.
Old 11-13-2007, 02:10 PM
1bigcamdls6's Avatar
i got my mods in sig and am runnin a totally stock rearend w/o upgraded output shaft...im on dr's and holdin up fine...if u arent goin for that 1.4 60' i think most stock differentials will hold up fine especially on the street where u cant grab as much as u can at the track
Old 11-13-2007, 02:16 PM
Evilways's Avatar
C5Z, right? The C6 rear isn't as sturdy of a piece as the C5s were. You have the rear and shafts that alot of C6 owners are upgrading to.
Quick Reply: C6 11.42@125 on runflats!!!!!!
