CRAP! So I'm chaning my oil and this is what I find. What is it?
Okay so I am in the middle of changing the oil on my Z, and I get the oil drain plug out, and this is what I find on it.
Sorry for the big pics.
My car has been running GREAT. I just put down 372 whp on the dyno maybe 10 days ago.
I'm so confused.
I'm so confused.
those needle bearings are probably from rocker arms, and that other piece looks like the valve spring seat or retainer. i wouldn't drive the car until u get it checked out
I had the same thing in my car and changed out all my roller rockers and then realized it was from my stupidity and it was actually parts of my roller pilot bearing that i knocked in and didnt realize it during a clutch install.
The pilot bearing for your clutch has nowhere to go.... hence it will grind away.
pull the valve covers and inspect the rockers. each rocker has needle bearing on each side, each side has 33.
happened to me. i found like 29, left it, next oil change i found 3, then next oil change i found the rest
Your oil drains from the top of the engine down.... so.... the needle bearings flowed down the drain holes, pushrod holes, etc until they get all the way to the bottom in the oil pan.... where the magnet catches 'em.
