first time at track with the Z
Old 10-19-2008, 11:46 PM
rio95cobra's Avatar
Default first time at track with the Z
and i couldnt get a good run in. I made 4 passes total, only one of them was good, and i still coulda done much better.
I am in need of the drill mod BAD! after maxing out 2nd gear, everytime i went to change, the clutch was to the floor. Absolutely could not put it in 3rd.
Best run was a 13.5 @101 with a 2.1 60'.
I had to litteraly shove into 3rd gear after maxing out 2nd, and it took me a second to do that, but at least i made a descent time.
The car:
'99 Z28 m6, ls6 intake,p/p throttlebody, slp lid, magnaflow bullet
245/16 street tires, stock 3.42's
Old 10-20-2008, 11:47 PM
rio95cobra's Avatar
what are normal times with these mods w/o shifting problems?
Old 10-21-2008, 12:31 AM
LM97Z's Avatar
What is the altitude of the track, your doing good for the 1st. time out, i would say you'll be in the 13.3s with some practice, maybe even 13.2s once you get that shifting problem solved, the MPH could be higher then 101 for an LS1, i would think 103-105 as a norm with some add-ons, so keep practicing.
As for the shifting issue, you can do the "drill mod" on the LS1 car, i'm of coarse running an LT1, i too had issues shifting into 3rd. at the track, but now i'm getting much better & hardly ever miss, it takes practice, i found out my car doesn't like to be "crammed" into 3rd., just don't get too aggressive on the 2nd./3rd. shift, let it find its way in, peddle to peddle timing also plays a big roll in the 2nd./3rd. shift, once you find that sweet spot that YOUR car likes, you should have it licked.
Old 10-22-2008, 01:34 AM
rio95cobra's Avatar
i have no idea what the altitude of the track is, but we went to Alabama international dragway in steele, alabama. At least i know my times arent too much off. I know it coulda been better though cuz i had to pause for a sec while getting it into third and still ran the 13.5. But yes, the drill mod is on the agenda for this weekend
Old 10-22-2008, 08:15 AM
S8ER95Z's Avatar
The drill mod will definately fix what you are describing...I have the same exact issue...I can nail my 1 to 2 as fast as I want but if I am even close to powershifting my 2 to 3 I get denied. Many aborted runs before I realised I just have to give it a moment and shift a bit slower on the 2 to 3.
All I do is just hit the clutch...count 1 thousand 1 and shift... seems to be enough to get me past the issue for now. I do want to know how well I would run if I didn't have to handicap my shifting technique.
Old 10-22-2008, 09:58 PM
rio95cobra's Avatar
haha counting to one thousand one and then shifting will **** your times up. ill let ya know how the drill mod works out on sunday
Old 10-23-2008, 07:55 AM
S8ER95Z's Avatar
Enh.. I figure running a 13.1 ~ 13.2 every pass versus missing the gear completely and letting off was a fair trade off.
Let me know... I don't want to start drilling into things just yet.
