Made a "few" passes, found out a few things - LS1TECH
Drag Racing Results Track Times | Records | Testing Info
Timeslip Database CLICK HERE
Thread Tools Search this Thread
Old 11-23-2008, 07:28 PM   #1
rel3rd's Avatar
Talking Made a "few" passes, found out a few things
Ran at Cecil County Dragway today during a private track rental.
I made a few passes (LOL) and also found out a few things about my car.
MY TIMESLIP INFO
Run - 60' ---- ET ---- MPH
#1 - 1.60 - 11.71 - 115.70
#2 - 1.62 - 11.70 - 116.09
#3 - 1.59 - 11.69 - 115.91
#4 - 2.43 - 15.28 - 73.00 (SPUN BAD and just cruised through)
#5 - 1.63 - 11.74 - 115.35 (tried adding 2* timing @ wot)
#6 - 1.58 - 11.66 - 116.22 (back to previous tune)
#7 - 1.59 - 11.66 - 116.14
#8 - 1.59 - 11.64 - 116.29
#9 - 1.60 - 11.72 - 115.43 (tried subtracting 2* @ wot)
#10- 1.60 - 11.70 - 115.90 (back to previous tune)
#11- 1.61 - 11.67 - 116.01
#12- 1.57 - 11.61 - 116.51 (New Best) (raised 1>2 shift rpm 100 rpm's)
#13- 1.57 - 11.62 - 116.45
#14- 1.59 - 11.67 - 115.74
#15- 1.58 - 11.63 - 116.46
#16- 1.60 - 11.64 - 115.84
#17- 1.57 - 11.62 - 116.32
#18- 1.61 - 11.66 - 115.75
#19- 1.57 - 11.62 - 116.17
#20- 1.57 - 11.65 - 115.50
#21- 1.59 - 11.66 - 115.71
#22- 1.57 - 11.62 - 115.93
#23- 1.58 - 11.67 - 115.52
What I found out:
1. My car LOVES being hot-lapped
2. The cutout makes no difference whatsoever (over my SLP dual/dual catback)
3. My car runs the same ET/MPH/60 foots with 342 gears, as it does with 410's.
4. My car runs pretty much the same 60 foots regardless of foot brake launch rpm.
5. If I didn't redlight every other pass, I'd be a helluva bracket racer, lol.
rel3rd is offline   Reply With Quote
Old 11-23-2008, 07:33 PM   #2
Unstang's Avatar
Congrats on the new best, you got your money's worth!!! I love looking at a list of consistent passes at the end of a track day too.
Unstang is offline   Reply With Quote
Old 11-23-2008, 07:39 PM   #3
rel3rd's Avatar
Quote:
I had a blast. It was great running pass after pass to end the season, just like I did back in March to start the season.
My previous record was a mere 21 passes, lol.
http://www.ls1tech.com/forums/drag-r...tml?highlight=
Old 11-23-2008, 07:39 PM   #4
MATTREDSS's Avatar
Congrats Bob on the new pb!
Matt
MATTREDSS is offline   Reply With Quote
Old 11-23-2008, 07:40 PM   #5
rel3rd's Avatar
Quote:
Matt
Thanks Matt. I just couldn't get that 11.5 though.
Old 11-23-2008, 07:42 PM   #6
Congrats. Damn I thought I was doing well to get 9 runs in at MIR. You got 23. When did you switch to 4.10's ? Are you still running the 226 cam? Your car is running well.
Hardtop is offline   Reply With Quote
Old 11-23-2008, 07:42 PM   #7
ndfrsd6's Avatar
congrats man very consistent
ndfrsd6 is offline   Reply With Quote
Old 11-23-2008, 07:48 PM   #8
Congrats nice run's
98blueSScamaro is offline   Reply With Quote
Old 11-23-2008, 07:54 PM   #9
rel3rd's Avatar
Thanks guys!
Quote:
I already took them out. I made a half dozen passes a few weeks ago with the 410's. I got a new best (that I beat 6 times today with the 342's back in), but I didn't like screaming the car from start to finish at the track...not to mention what little gas mileage I got, disappeared.
Yep, still running the old tried and true hand me down PSI 226 cam.
Heck, I got 21 passes at MIR back in March for that rental Jason Miller had on Good Friday.
Old 11-23-2008, 07:55 PM   #10
MATTREDSS's Avatar
Quote:
Bob you will get 11.5s soon. Is your car full weight?
Old 11-23-2008, 07:59 PM   #11
rel3rd's Avatar
3755# (with me in it) according to MIR's scale when I met you last March.
Probably 20# heavier at the moment...
I wouldn't mind shedding some weight off of it, as long as it didn't look like it was gone...if you know what I mean? Losing ac and stuff like that is not an option, but losing stuff that doesn't affect safety or comfort is fine.
Old 11-23-2008, 08:00 PM   #12
Sharpe's Avatar
Nice runs. What are all your mods, including suspension and tires?
Thanks.
Sharpe is offline   Reply With Quote
Old 11-23-2008, 08:06 PM   #13
LS1 SPEED's Avatar
nice and consistent..congrats
LS1 SPEED is offline   Reply With Quote
Old 11-23-2008, 08:10 PM   #14
rel3rd's Avatar
Thanks guys! I appreciate it.
Quote:
Thanks.
Pretty simple, cookie cutter combo IMHO.
Race weight is 3755#
Drivetrain:
stock 116,000 mile bottom end
226 cam
LS6 intake
Home ported throttle body
SLP lid
SSRA (SuperSuckerRamAir)
EGR/AIR deleted
March UD crank pulley
PI Vigilante 3600 stall
Stock, untouched 4L60E
342 geared 10 bolt w/Summit girdle
Suspension:
Bilstein shocks/struts
1LE coil springs
Stock torque arm
Stock front & rear swaybars ON and hooked up
Stock, boxed lower control arms
Stock, boxed panhard bar
Wheels/Tires:
15x3.5 ProStars w/Kumho 165R15 front tires (44psi)
15x8 ProStars w/ 275/50/15 MT Drag Radials (20psi)
Tuned by me with HPTuners software w/expert help & advice from Frost @ LSxTune.com
Old 11-23-2008, 08:59 PM   #15
Thanks guys!
Thanks for doing the bigger gear experiment for me. Guess I'll stay with the 3.42's.
Old 11-23-2008, 09:06 PM   #16
nice times i try to tell everyone gears arent worth it in a 10 bolt..., that is really good for the weight...
chrs1313 is offline   Reply With Quote
Old 11-23-2008, 10:41 PM   #17
rel3rd's Avatar
Yeah, it was a cheap enough experiment. I swapped one of my spare 3 series carriers for a 2 series, so I could use a thick (and hopefully stronger) ring gear.
I had all of the bearings already, so I just had to buy a cheapo set of Summit brand 410's, which actually setup nice and easy, and were quiet as stock.
Old 11-23-2008, 10:43 PM   #18
rel3rd's Avatar
Quote:
Thanks a lot. I'm half tempted to swap the original 323's back in. (I only have 342's due to swapping in an older stock M6 rear)
Old 11-24-2008, 08:53 AM   #19
DKITCHEN's Avatar
Ditto on the gear experiment! I keep thinking I need to move up from the 3.23's to at least a 3.73. I guess I'll just do the headers and catback next and see what it runs with the stock gears. Great passes! I hot lapped about 3 times at MIR yesterday and picked up mph on the both of the hot laps. Too bad I was spinning on those runs
DKITCHEN is offline   Reply With Quote
Old 11-24-2008, 09:22 AM   #20
rel3rd's Avatar
Glad to help, lol.
Some things we need to just DO and figure out ourselves if they work in our combos.
The gears were a perfect example.
Some insisted the car would go quicker with more gear...It didn't.
Best pass 3 weeks ago (in very similar weather) with 410's was a 11.63@116 w/1.57 60'
A year ago, I removed front swaybar, added adjustable rear shocks, Spohn chassis mount torque arm, Spohn 25mm rear swaybar, and Spohn double adjustable panhard bar.
I did this because everyone said my stock suspension was hurting performance.
Guess what? Sixty foots were worse than now with STOCK everything. My best 60 foot ever with all the suspension stuff was 1.58 (Average of 1.61). My "average" yesterday was 1.59, with several 1.57's. So...2/100ths better average 60 foots by selling all of my high dollar suspension stuff.
I run JetHot 1-3/4" longtubes, Off Road Y, SLP dual/dual catback.
Everyone swears the cutouts add horsepower, MPH, better ET, etc...
I installed one and with it open got exactly .009 better...hardly a worthwhile investment for "my car", and proof (to ME) that the dual/dual works pretty damn good. I must admit though that I left it open all day as it does sound good at WOT.
It looks like my car is at a plateau since no matter what I do at this point, the car runs the same...I can add timing, subtract timing, launch low, launch higher, add fuel, subtract fuel...it makes no difference.
Related Topics
Thread Thread Starter Forum Replies Last Post
Quickest STOCK INTERNALS List - 11.77 bump! WILWAXU Drag Racing Results 24 12-12-2008 12:08 AM
Quickest STOCK INTERNALS List - 11.79 bump! WILWAXU Drag Racing Results 171 09-28-2008 11:02 AM
Made a few passes @ MIR...lol. rel3rd Drag Racing Results 29 04-06-2008 03:09 PM
2007 Nitrous ET List next Nitrous Oxide 320 01-30-2008 06:13 PM
Quickest STOCK INTERNALS List - 11.901 bump! WILWAXU Drag Racing Tech 72 02-09-2004 08:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
