Fastest N/A, Cam Only, all LS engines
Old 12-08-2008, 06:31 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Post Fastest N/A, Cam Only, all LS engines
Since the LS-engine series has evolved, I decided to take the "Fastest Cam Only LS1/LS6" list and update it to include LS2, LS3, etc. All times must be on stock heads, crank, rods and pistons. Post up your times and I'll bump and add as I can. Keep in mind it may take a little bit longer to update the list at certain times, but I have a life outside the board too (amazing right?)
For Updates...
I need your ETs out to three decimal places, (i.e. 11.XXX) and include all the information required for the list.
Put information in the following format:
Board ID - 1/4 ET @ MPH (60ft), Year & Type of car, Engine type, Transmission, Converter or Clutch, Gear Ratio, Cam (with specs if not a widely known one), DA, Race Weight, Date
EDIT: have updated to now include LS7 and other LS-based engines. So post up your times!
Old 12-08-2008, 06:33 PM
7 Second Club
LS1 / LS6 engines
Board ID - 1/4 ET @ MPH (60ft), Year & Type of car, Engine Type, Transmission, Converter or Clutch, Gear Ratio, Cam (with specs if not a widely known one), DA, Race Weight, Date
F-body
1. SSPerformance 9.986 @ 132.27 (1.31), 94 Z/28, LS1, TH350, ATI, 4.33, TRex, -270, 2900 lbs, 11/10
2. Smokin01ta 10.219 @ 132.29 (1.38), 01 T/A, LS1, M6, Spec4, 4.56, TRex, -1100, 3010 lbs, 3/06
3. LS1Joe 10.232@132.04 (1.39), 02 Z/28, LS1, M6, Spec4, 4.71, 250, -1100, 3150, 03/06
4. Josh@KY-Turbo 10.291 @ 128.07 (1.33), Z/28, LS1, TH400, 5100, 4.11, 239/247, 878, 2953, 9/11
5. 01-Z 10.295 @ 128.48 (1.38), 01 Z/28, LS1, TH400, 5500, 4.57, G5X4, -110, 2880, 4/05
6. Magnus 10.295 @ 128.48 (1.36), 97 Firebird, LS1, TH350, 5500, 4.10, G5X4, 200, 2820, 4/05
7. Dragaholic 10.340 @ 127.46 (1.36), 00 SS, LS1, TH350, 5500, 4.56, TRex, -700, 2850, 11/05
8. Minshall 10.384 @ 127.53 (1.37), 02 Z/28, LS1, TH400, 5000, 4.10, G5X4, +1897, 3125, 10/10
9. SSmokedLS1 10.48 @ 130.29 (1.45), 01 T/A, LS1, M6, Spec4, 4.56, TRex, 800, 3035, 3/07
10. Johnathon @ Tick 10.509 @ 131.99 (1.478), 99 T/A, LS1, M6, McLeod Slipper, 5.00, The Polluter, 48, 3020, 11/09
11. Trevor @ TSP 10.510 @ 125.80 (1.43), 98 Z/28, LS1, 4L60E, 4500, 4.56, MS3, -1000, 3175, 2/05
12. fatboyzcamaro 10.550 @ 125.38 (1.390), 00 Z/28, LS1, TH400, FTI 5200, g5x2, 3.70, unknown, 3120, 11/11
13. Project_SS 10.561 @ 126.74 (1.44), 98 SS, LS1, 4L60E, 4400, 3.73, Vind, 2400, 2840, 7/07
14. Chrs1313 10.617 @ 124.66 (1.356), 02 Z/28, LS1, SS4000, 230/230, 4.10, -870, 3250, 10/09
15. studderin 10.660 @ 129.89 (1.482), 01 Z/28, M6, Ram HD, 4.30, street sweeper, unknown, 3160, 11/11
16. DMcRacer 10.738 @ 125.06 (1.46), 02 SS, LS1, 4L60E, 4600, 3.42, AMS, -1080, 3375, 1/05
17. Jason99ta 10.783 @ 128.27 (1.56), 99 T/A, LS1, M6, RAM, 4.56, TRex, 1300, 3253, 06/04
18. CanuckSS 10.793 @ 128.96 (1.59), 98 SS, LS1, M6, Spec Stage 5, 4.56, TRex, 580, 3000, 10/10
19. GrannySShifting 10.821 @ 126.9 (1.47), 97 SS, LS1, M6, Tex, 4.56, PSI 233/238, -1000+, 3458, 11/08
20. Demonicbird00 10.846 @ 127.80 (1.571), 00 T/A, LS1, M6, SPEC Twin, 4.10, KOD 245/250, -1181, 3190, 11/10
21. PewterZ28 10.857 @ 123.53 (1.46), 02 Z/28, LS1, TH350, 4900, 4.10, G5X4, 46, 3310, 10/06
22. BAIN 10.871 @ 122.24 (1.49), 00 SS, LS1, 4L60E, PTC 5100, 4.10, TR T-Rex, -157, 3260, 10/09
Corvette
1. Roger White 10.869 @ 123.04 (1.46), 02 C5, 4l60e, 4400, 3.90, M2,-1000, 3350, 11/03
2. Redgar 10.968 @ 124.66 (1.50), 99 C5, 4l60e, 5000, 3.90, VD, -800, 3400, 11/05
3. Robz 10.968@124.32 (1.46), 03 Z06, M6, Cartek, 3.90, 2x, -1000, 3250, 11/03
4. blk04z 11.167 @ 123.56 (1.59), 04 Z06, M6, RPS, 3.42, TR230/236, -800, 3186, 11/07
5. Skinny Kid 11.258 @ 125.11 (1.75), 02 Z06, M6, Textralia Twin, 3.42, MS4, -888, 3280, 11/09
6. BLU-BY-U 11.281 @ 121.20 (1.51), 02 Z06, M6, clutch, 3.90, RPM, -670, 3220, 1/05
7. MadDawg 11.516 @ 117.40 (1.64), 01 C5, 4l60e, 3200, 3.15, Stealth2, -661, 3310, 2/05
GTO
1. Joeyelbows 12.186 @ 114.35 (1.78), 04 GTO, M6, LS7, 3.46, 207/220, DA unknown, 3500 lbs, 12/08
Hybrid / Conversion
1. Ablakez28 11.021 @ 126.01 (1.557), 93 RX7, LS1, M6, LS7, 4.10, TRex, DA unknown, 2650, 7/10
2. cnichols 11.849 @ 122.74 (1.82), 96 240 SX, LS1, M6, LS7, 3.92, MS3, 600, 3000, 11/08
Old 12-08-2008, 06:36 PM
7 Second Club
LS2 engines
Board ID - 1/4 ET @ MPH (60ft), Year & Type of car, Transmission, Converter or Clutch, Gear Ratio, Cam (with specs if not a widely known one), DA, Race Weight, Date
Corvette
1. Tony B4 10.844 @ 125.83 (1.53), 06 C6, A6, 3600, 2.56, Cartek 3X, DA unknown, 3300, 10/09
GTO
1. GTO-Jester 11.56 @ 117.59 (1.63), 06 GTO, T-56, Monster Stage 3, 3.46, StreetSweeper, DA unknown, race weight unknown, 10/10
Hybrid / Conversion
1. dlove 10.46 @ 128 (1.47), 00 Z/28, Powerglide, Circle D 5C, 3.73, 231/239, +1000, 2800, 10/08
Old 12-08-2008, 06:37 PM
7 Second Club
LS3 engines
Camaro
1.
Corvette
1.
Hybrid / Conversion
1.
Old 12-08-2008, 06:38 PM
7 Second Club
LS7 engines
Corvette
1. LEO 11.26 @ 129.07 (1.87), 2006, M6, Comp 230/242 LXL lobes, unknown DA, unknown lbs, 1/13
Hybrid / Conversion
1.
LQ engines - Hybrid / Conversion
1. billyflantos 9.81 @ 134.73 (1.34), 87 Mustang, LQ4 w/ 799 heads, Powerglide, ATI 4500, 4.10, Polluter, +1300, 2700, 10/10
2. DMMizell 9.871 @ 136.83 (1.382), 90 Mustang, LQ4 w/ L92 heads, TH350, 3800, 4.10, Rapid Motorsports Dominator 2X, 2900 lbs, 4/10
All other LS-based engines - Hybrid / Conversion
1. MustangLS 11.40 @ 117.88 (1.59), 94 Mustang, 5.3L, TH350, FTI 4400, 3.73, MS3, +426, 3114, 11/12
Old 12-28-2008, 11:07 PM
JRracing's Avatar
I see you put up a list for the conversion people. Good, I'll be all over it this season with my fox body mustang. I'm sure there will be a lot of people getting on it. Phil should be at the top or close to it lol.
Old 06-28-2009, 05:47 PM
SMOKIN01TA's Avatar
Hey Derek, thanks for taking over that list stuff for me, i havent talked to you fellas in a while.
Old 06-28-2009, 09:04 PM
7 Second Club
Good to see you back again!
Old 10-12-2009, 12:01 PM
98blueSScamaro's Avatar
98blueSScamaro - 10.88 @ 126.81 (1.48), '98 camaroSS LS6, M6, 0z700, 4.56s, vindicator , -800, 3475, 10-11-09
Old 10-12-2009, 02:56 PM
02SLOMARO's Avatar
man! some of these cars are flyin! i noticed that the real fast ones are 3100lbs or less. some even 2800lb.
Old 10-12-2009, 04:59 PM
chrs1313's Avatar
4 spot bump up
Chrs1313 10.617 @ 124.66 (1.356), 02 Z, SS4000, 230/230, 4.10, -870, 3250, 11/09
new 60ft record!!!
Old 10-12-2009, 08:11 PM
Magnet's Avatar
so.. you go on the vette list?
Old 10-12-2009, 08:48 PM
I dunno how they work it i saw it said ls1/ls6 so it may be on the vette list
Old 10-12-2009, 11:42 PM
studderin's Avatar
I'm here for the gangbang
https://ls1tech.com/forums/drag-raci...2-127-5-a.html
studderin 10.841 @ 126.83, 1.499, 01 Z, LS1 ,m6, Ram HD, 4.30, street sweeper, 700, 3250, 11/09
Old 10-13-2009, 07:23 PM
7 Second Club
Updated, now we have a good top 20 so unless we get a solid 25 under 11.00 I'll cap it at 20.
Let's see if anyone can crack some good times at the LSX Shootout this weekend....
Derek
Old 10-14-2009, 10:59 AM
AChotrod's Avatar
DAMN this Gto got some serious MPH LOL!!!
GTO
1. Joeyelbows 12.186 @ 1114.35 (1.78), 04 GTO, M6, LS7, 3.46, 207/220, DA unknown, 3500 lbs, 12/08
Old 10-14-2009, 01:13 PM
TOSTO RACING's Avatar
I hurt my stock eliminator motor so guess what next year I'm gunning for you guys I'm buying a brand new gm longblock so we'll see what happens.
I'm gonna have the Jerico behind me so it should be fun.
Old 10-14-2009, 02:18 PM
Oh no hahaha what did you hurt in the motor??
Old 10-14-2009, 05:46 PM
Hurt a cylinder. So I just pulled it and gonna start over.
I just wanna go for the cam only record is the real reason lol.
Old 10-14-2009, 06:04 PM
Hurt a cylinder.
I just wanna go for the cam only record lol
well your car is set up so i dont think it will be a problem going low 10's for you
Rob
Quick Reply: Fastest N/A, Cam Only, all LS engines
