Stock block KYTP TC76 shakedown runs
Well I finally found enough time to get to the track today and make a couple of shakedown passes. This is the first time I have ever ran a car with an auto in it or using a trans brake as well (Thanks Greg @FTI,I absolutely love it). The first pass off the trailer was a 6.97@107.6 off of idle w/ a 1.69 60'. After that I knew it would end up being a good day. I still need to work on my launch rpm and the anti lag feature on the Lingenfelter launch control but a 3600 launch rpm got me a 1.46 60' on the last pass of the day in the video below!
http://www.youtube.com/watch?v=H0hPMuMzRS8
If anyone is interested the car is on a completely stock block with patriot stage 2 heads (59cc) and TSP T.V.3 cam and tuned on E85 w/ 7 psi. The h/c set up is obviously not ideal for a turbo but it is gonna get the job done untill the new motor goes in. Car weighs 3490 w/ me if you're wondering!
The suspension on the front of the car is completely stock including the shocks just lowering springs. The rear is a spooled 3.70 M9 w/ BMR ajustable everything with anti roll bar and also stock shocks! The tires are M/T ET streets 26x11.5x15! The transmission is a TH400 from FTI converters and the stall is roughly 4,000 also from FTI. I am using the launch controller but I am not pulling any timing nor do I think I even hit the rpm cut on the launch yet. So I still have some playing to do! You can see in the video that the boost doesn't really come in good until about 30' out! If I can get the launch better by bringing the boost in sooner then I believe 1.3 short times and low 6.5's are very possible!
