So my car only trapped 86 in the 1/8??
Old 04-11-2009, 11:18 AM
1badnova496's Avatar
Default So my car only trapped 86 in the 1/8??
I took my car down the track lastnight for the first time with this combo and it didn't turn out good. My best 60' was 2.33 with 285/35-18 tires. Any suggestion why it was this slow?
Old 04-11-2009, 11:47 AM
TABBED 5.3's Avatar
the 2.33 60 ft. might have a little to with that low trap. how much does the car weigh?
Old 04-11-2009, 12:28 PM
01_ram-air's Avatar
It's because you're spinning really bad. Put a REAL tire on the car and then see what it does.
Old 04-11-2009, 12:31 PM
Magnet's Avatar
yea something is up... my car did 87 in the 1/8th and it has a lid, homemade ram air, and ported TB.. stock tires..
Old 04-11-2009, 03:42 PM
I'm not sure what the car weighs. I don't have any weight reductions and it does have an iron block in it.
Old 04-11-2009, 04:11 PM
Moderator
davered00ss's Avatar
What was your ET?
What tires are you running?
Get it on the dyno and see what it puts down for rwhp & rwtq.
86 in the 1/8, what was that a low 8 sec et? Should be mid/high 12's in the 1/4?
Old 04-11-2009, 08:30 PM
My best 60' was 2.27 instead of 2.33 and i went 8.74@86.05. This was with radial tires. No drag radial
Old 04-11-2009, 08:32 PM
What made me feel worse was i ran against a 2002 Z28 auto with headers and drag radials only and i still couldn't pull on him at all
Old 04-11-2009, 09:10 PM
TABBED 5.3's Avatar
its almost impossible to compare times if you are running street tires with a h/c set-up. get the 60 ft. to at least 1.9 and then you kind of figure where you stand.
Old 04-11-2009, 09:51 PM
crazymagman's Avatar
Street tires are a killer. The best I've run so far is a 2.2 60' and 8.34 at 85mph. Think I spun the first whole 60'....... I need to get back out there and get some more practice.
Old 04-11-2009, 10:37 PM
jsteele90's Avatar
ive ran a 8.0@86 on street tires before with a 1.8 60 ft before the h/c setup.
Old 04-13-2009, 07:34 AM
s346k's Avatar
i'd get the car to a tuner. even with a poor 60' that particular engine combo should definately be trapping higher. my wife snagged a sweet 2.6 60' in her 99 m6 ta and still managed to trap 88 with a lid and weld in flowmaster 80 series as the only "mods".
Quick Reply: So my car only trapped 86 in the 1/8??
