Not happy with results.
Old 04-27-2009, 03:59 PM
MYSTIC-1SC's Avatar
Default Not happy with results.
well, i got my 3.73gears installed and went to the track and ran 7.68 at 88 mph on motor, my previous best pass was a 7.69 at 91 on motor with my 2.73 gears. I realize that the temperature was up a bit higher, but i figured i would see some better results. The car has been retuned for the gears and i figured that i would notice a nice improvement. Oh and the reason i decided to change the gears is because i have a cam fixing to go in and i knew the 2.73 gears just wouldn't work out well. But let me know what you guys think, i am pretty dissapointed.
Old 04-27-2009, 09:47 PM
Photochop's Avatar
Its all in your 60' man. Mine went 7.22 @ 98 in the 1/8 last weekend, your MPH is showing pretty good HP
Old 04-27-2009, 09:55 PM
86 IROC's Avatar
You picked up 7 MPH? I'd say that's damn amazing from just a gear swap.
Old 04-27-2009, 09:56 PM
waterbug1999's Avatar
What was the 60' times on the two runs your comparing?
Old 04-27-2009, 10:28 PM
BAIN's Avatar
No way you ran 98 mph with the mods you have. You must have been spinning bad.
Old 04-27-2009, 11:00 PM
JonCR96Z's Avatar
Yeah you really shouldn't have gained much if any MPH. I can't even see spinning being more than 1-2 MPH.
What were the 60's and 330's for the before and after runs?
Old 04-28-2009, 07:11 AM
MYSTIC-1SC's Avatar
im sorry that was a misprint i meant 88 mph.
Old 04-28-2009, 07:15 AM
MYSTIC-1SC's Avatar
my 60ft only improved to a 1.68 from what it used to do consistantly which was a 1.71 60ft with the 2.73s. my best 60ft with the 2.73s was a 1.69. i just figured i would get better results. Let me know what you guys think.
Old 04-28-2009, 11:26 PM
fly pantera's Avatar
you must have ran in better da when you had your 2.73,cause you should pick up mph.I believe i picked up 3mph when I went to 3.73 from 2.73.theres a thread check my profile
Old 04-28-2009, 11:39 PM
JonCR96Z's Avatar
Agreed. He did say that the temp was hotter. It's always important to keep up with actual temp and overall DA whilst comparing mods.
Old 04-29-2009, 01:07 AM
StreetSilverado's Avatar
Don't be too bummed, I managed a 1.8x 60ft 7.87 1/8 at 91.xx mph
Old 04-29-2009, 07:04 AM
MYSTIC-1SC's Avatar
thanks guys.
Old 04-29-2009, 12:40 PM
5_02ls1's Avatar
I cant say what i gained from a 273to373 swap but i done full bolt ons the 3.73s and a taune and gained 1.1 off my e/t and 6mph....this was on the stock verter though......seems a gear swap doesnt benefit a stalled car as much....god i miss that setup...lol
Old 04-30-2009, 11:28 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Agreed, between personal bests and spring/summer air my car will differ by 3 to 4 tenths. You can't compare apples to oranges.
Derek
Old 05-01-2009, 06:42 PM
yarrie's Avatar
MYSTIC-1SC could u post all times and speeds throughout the entire run so i can compare them to my slips. my car dont shift to 3rd at wot i think i need a tune but i have the same mods. as u and i was just wondering what to expect when i get her shifting i went 1.67 60ft. and 7.93@85.69 not shifting into 3rd.
Old 05-06-2009, 09:39 PM
UFAIL's Avatar
its all in the weather wait till summer and they will get worse. don't get down about it. gears don't effect a higher stall car well not much anyway.
