pt88 @15psi results
pt88 @15psi results
turned the boost up to 15, 6.0 stock crank, weisco pistons and carillo rods. TH400 with a moser 9in, 3.25 gear, tunnel torque spohn TA, spohn LCA. Stock shocks, prokit springs. car went 6.28@114.8 with a 1.53 60ft.
forgot to add:
Stock shocks
Stock TB
LS6 intake
6.0 manifolds
317 6.0 heads
LQ9 block 0-ringed
Hptuners
Full interior
AC delete
.575ish cam
3.25 gear
th400 w/brake
ebay intercooler
ebay piping kit
60lb siemens @110%
Stock shocks
Stock TB
LS6 intake
6.0 manifolds
317 6.0 heads
LQ9 block 0-ringed
Hptuners
Full interior
AC delete
.575ish cam
3.25 gear
th400 w/brake
ebay intercooler
ebay piping kit
60lb siemens @110%
the plan is to turn it up to about 20-25psi soon and see how stock 6.0 heads handle it when it is oringed. their is a lot of talk about thick decks and pricey gaskets. so far ive hit 19psi with a lean a/r and no water push. also i have standard mls gaskets and standard arp studs torqued to 80 ftlbs, i know thick decks work great and the 6 bolt block is even better. but financially i cant do it.
