12.2@116 torquer V.2 cam only
Old 07-11-2009, 01:16 AM
smnitFB's Avatar
Default 12.2@116 torquer V.2 cam only
went to the track this evening, was having major traction issues. Finally found the problem on the third run. The torque arm rubber bushing must have been working it's way loose, because it popped out of the mount on the third run completely. I had to crawl under it and put it back it, unfortunately by the time I got that done, they were rapping up and I didn't get to try it out with the mount fixed. First two passed I was launching between 4500 and 5000. Was feathering it the first pass to try and stop the spinning. I think I've got the air pressure down, the M/T's like 15psi cold. I'm still working on adjusting the shocks. Car is just bolt ons and a torquer V.2 cam. I swapped in my moser 9" with 4.11's/locker/35 splines. I've still got some tweeking to do, but not bad for the first time I've had this car out. It's got good trap speeds, I should see 11's next time out. Vids and timeslips attached. Also found the tack is 300 rpm slow (I knew they were slow), hit the 6800 limiter at 6500 on the tack on the last run. Shift light is coming. BTW runs are from right to left, with right being the first run.
View Video on FQuick
Old 07-19-2009, 12:07 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Nice vids. Keep working at it. Good luck.
Coach
Old 07-19-2009, 12:56 PM
blue98Z's Avatar
Just get that thing to bite man and 11's will be gravy.
Old 07-19-2009, 07:59 PM
HaulinHawk's Avatar
Get that 60ft down and u will be in the mid 11's easy.
Old 07-19-2009, 11:03 PM
smnitFB's Avatar
That's the goal, I've been tweaking the suspension here and there trying to get it right. I should be back out on Friday. I'd like to see some 11's before I tear it all apart this winter.
Old 11-07-2009, 01:58 AM
bad6as's Avatar
try 1 on the front and 3 in the rear on the shocks. my best with teh 3.90s in that car was 11.98 and that was be for the last round of lil mods i did to it
Old 11-09-2009, 07:02 PM
transamman1234's Avatar
Check out that reaction time!!! Smokin' quick footwork there! nice
Quick Reply: 12.2@116 torquer V.2 cam only
