My 6spd TA 10 bolt held my first 10 sec pass
Like the title says, my 10 bolt held up to my first 10 second pass. The car is a 98 TA with a LQ4 shortblock with ARP rod bolts, 5.3L heads with LS1 valves installed but still un-ported!, FAST 90/90, NX 150 shot, LT's, ORY, E-Cutout, 160* stat, Lid, stock rear with GM 3.73 used gears, stock stamped steel suspension, V6 front springs, stock rear springs, Comp Engineering 3 way Drag Shocks, KY-Clutch and a SD ShorTune.
Here is the video of the pass. I'm very sure there is more left in the car with a stronger rear that will hold a much more violent launch.
DA at time of pass was 3050ft
London Dragway - London KY
80.1*F
52% Humidity
29.98 in.Hg Barametric Pressure
1244ft elevation
1.56 - 60ft
7.03@100mph - 1/8
10.91@128.1mph - 1/4
http://www.youtube.com/watch?v=A6BMH0qabxg
80.1*F
52% Humidity
1244ft elevation
1.56 - 60ft
7.03@100mph - 1/8
The nitrous does most of the work there... I've not gotten any good NA passes with the car because of the tall 28" slick I run and the 3.73 gear. It needs alot more gear like 4.30's or so with a 28" slick to do much on motor. But the best i've gotten NA so far is a 12.21@119mph that was on a 1.84 60ft.
Just to add to the specs on the car... it is FULL weight and still has A/C that blows cold. All bumper supports still intact, all sway bars. Only weight reduction at all was the wheels and tires.
