First time 1/4 mi.
First time 1/4 mi.
Well I finally made some runs in the 1/4 mi. All this summer I was running the 1/8 mi. Here are my times and I would appreciate any input good or bad. Thanks
(1) (2) (3) (4) (5) (6)
60ft. 1.974, 2.004, 1.968, 1.977, 1.989, 1.986
330ft. 5.461, 5.503, 5.486, 5.454, 5.490, 5.526
660ft. 8.269, 8.326, 8.293, 8.255, 8.287, 8.345
660mph 87.36, 87.30, 87.45, 87.46, 87.42, 87.18
1320et. 12.744, 12.796, 12.772, 12.720, 12.764, 12.838
1320mph 111.08, 108.78, 110.91, 111.27, 110.96, 110.52
DA....... beginning 1567 ending 1842
Slp.cold air, LT's, LS6 intake, ZO6 head and cam pkg., 3" loudmouth catback exhaust, stock 4L60E trans and converter, 373's with eaton posi, 275x60x15 M/T DR's, skinnies with Weld wheels 15x10, 15x4, weight w/driver 3540.
That doesn't mean something is wrong with his car. The LS6 package isn't that big of an upgrade, and he's on a stock stall in sub-par weather running the same times as you.
Thanks for the input, it's really appreciated. 3 weeks left before our track closes for the season so ....... CONVERTER will be for next year. As for the question, peak torque was at 4270.
I also agree that the stock stall is holding you back. The best I have ran is a 12.84@107.7 with stock gears, internals and trans/stall....
Even though your heads and cam aren't a super serious mod with a stall you should be high 11's one would think, as long as the weather and track prep are there.
I would also think that the 3.73s would at least get you into the low 1.9's high 1.8s...
In the future when you go with a bigger cam the stall will help alot and should put you deep in the 11's.
