383 timeslip help
Old 09-29-2009, 11:42 PM
fbodyman1026's Avatar
Default 383 timeslip help
My friend and I need help figuring out what is wrong with his car. Here is a quick run down on the car.
01 z28
383 stroker approx. 11.1 Compression
MS4 cam
5.3 Stage 2.5 Heads
Fast 92/92
85/85 Lid and Maf
1 7/8 Texas Speed Long Tubes
Texas Speed 3 inch True Duals
-Drivetrain
TH400 4200 Circle-D Stall, TCI Flexplate
Moser 9inch Detriot Locker, 35 spline, 4.11 gears
3.5 inch steel driveshaft
Full suspension beside drag bar.
The car put down 430rwhp/370rwtq on a mustang dyno.
He previsouly ran 11.4@120 w/ 1.8 60' ni bad weather on a slick track. This past weekend we went back to milan which was well prepped. He cut a 1.63 60' this time and went 11.5@119???? DA is around ~1500.
Even disregarding the slower time with a better 60' this car should be cutting a way better 60' and going at least high tens IMO. What should we look for and do? It's going back on the rollers thursday to get everything checked out. He is close to saying F*** it and putting a 200 shot on it.
Thanks guys.
Old 09-30-2009, 04:04 PM
anyone willing to chime in here??
Old 09-30-2009, 07:37 PM
Fifedogg's Avatar
What tires was the car on?
Old 09-30-2009, 07:58 PM
69LT1Bird's Avatar
How much is the race weight. I don't see high tens but who knows, maybe.
Old 09-30-2009, 08:48 PM
Magnet's Avatar
Honestly the times seem right for 430rwhp assuming your near stock weight...
Old 09-30-2009, 10:29 PM
silverz28camaro's Avatar
Agree, I think a 12 bolt with 30 spline axles would have been more efficient and maybe a 3600 converter. Weigh the car and let us know what it is.
I never did like the 5.3 heads, never saw impressive numbers, I would think a set of trick flow 215 would let the bigger cubes breathe alot better. notice what rpm are you at near the end of the traps. if you are abouve 6200 i can see the trick flows picking up power.
Old 10-01-2009, 12:20 AM
28x10 MT et streets
stock plus roll cage
Originally Posted by silverz28camaro
Agree, I think a 12 bolt with 30 spline axles would have been more efficient and maybe a 3600 converter. Weigh the car and let us know what it is.I never did like the 5.3 heads, never saw impressive numbers, I would think a set of trick flow 215 would let the bigger cubes breathe alot better. notice what rpm are you at near the end of the traps. if you are abouve 6200 i can see the trick flows picking up power.
Not 100% sure on the rpm but it is up there. 6200+
Old 10-01-2009, 11:26 AM
stumprrp's Avatar
the car should be close to high 10's my car did 11.9 @ 3460 lbs with only 340 RWHP.
Old 10-01-2009, 02:11 PM
Went back on the dyno today and only put down 360rwhp! Were thinking it's a valve spring problem and tsp is looking into it. But 11.5 with only 360 is good in our book.
He is Thinking of a head swap to some 205/225 afr's not sure which to go with tho...
Quick Reply: 383 timeslip help
