Live from the LSX Shootout: POLLUTER Cam Only Times!
Finally got some decent times out of our Cam-Only Shop Car. After fighting suspension issues at the LSX Shootout last year, we're back this year with a new setup and it's running very well!
STOCK 1999 LS1 Shortblock with Katech Rod Bolts, Stock untouched 241 heads, Edelbrock intake and The Polluter, our flagship camshaft. 3020lb raceweight and -716 DA. Jonathan@Tick is rowing one of our Level Three EXTREME Viper T56 Rebuilds to the following:
60': 1.455
1/8: 6.735
1/4: 10.568
MPH: 127.92
This was our first pass of the day, so hopefully we'll be able to improve as the weekend progresses. Currently, our 10.568@127.92 is good for 9th on the cam-only list.
We're vending here as well, so if you're here, feel free to stop in and say hi!!
60': 1.455
1/8: 6.735
1/4: 10.568
MPH: 127.92
nice times guys, looks like you caught some good air too...and i am pissed you bumped me off my spot...
looks like i am going to have to lose 230lbs and reclaim it haha...
i think there is more in that setup...does it have every bolt on
the baro is going up there too...so you will only get faster as night fall sets in...
LS1TECH Sponsor
The ports on the intake are a good bit larger than the factory ports on the heads already, but it still makes decent power...
LS1TECH Sponsor
5.00 gears. We're launching at 7800 rpms off the two step and shifting at 7400 rpms. Its crossing the traps at around 7600 I think.
And before anyone asks, it does have katech rod bolts on an otherwise stock shortblock with the original rings, bearings, etc. The engine has around 55,000 miles on it if I recall correctly.
Heres the numbers for the last and best pass of the day:
r/t .044
60' 1.471
330' 4.335
1/8 6.73 @ 102.24
1000' 8.804
1/4 10.555 @ 128.14
r/t .044
60' 1.471
330' 4.335
1/8 6.73 @ 102.24
1000' 8.804
1/4 10.555 @ 128.14
nice runs. are you guys still using the stock wet sump oiling? also...do you have a dynograph of that super vic with stock heads and that cam? not interested in numbers as much as i am the powercurve. i assume this is an off the shelf polluter...112 lsa most likely 4* advance?
