Time for a drag bar /sway bar
Old 10-26-2009, 07:51 PM
BADHAWK51's Avatar
Default Time for a drag bar /sway bar
I went to the track yesterday looking for a NB but it didn't happen. The car was twisting so badly I just called it a day after 2 passes and went and watched the Bears get destroyed.
Results were 11.193 @119 1.48 sixty
11.103 @119 1.46 sixty
Old 10-26-2009, 08:58 PM
bad2000z's Avatar
I had the BMR drag bar on my Z28, it worked great.
Old 10-26-2009, 09:48 PM
BADHAWK51's Avatar
Thanks I got to get one soon.
Old 10-26-2009, 10:33 PM
robsquikz28's Avatar
That is one badhawk man...lol holy squat and twist batman.
that on spray or all n/a
Old 10-26-2009, 11:12 PM
BADHAWK51's Avatar
Thanks man, That is n/a.
Old 10-28-2009, 03:16 PM
J-R10-5's Avatar
That sure as hell isn't Chicagoland.
You're almost pulling the drivers wheel off the ground - that's not good
I want to guess at the car in the other lane. Hopefully you remember
Old 10-28-2009, 10:03 PM
BADHAWK51's Avatar
The pic I posted is from Bryron IL it looks similar to the shot from the shootout but is a totally different shot.
Old 10-28-2009, 10:15 PM
BOLO's Avatar
Jeff, you definitely need a drag bar with all that power twisting the car drastically. Is the car still have the stock piece?
Old 10-28-2009, 11:27 PM
BADHAWK51's Avatar
Ya it's still the stock piece Butch and the Circle D converter hits really hard I'm loving it. Hoping with the drag bar might even bring the sixty down a touch more.
Old 10-30-2009, 01:27 PM
FASTFATBOY's Avatar
I put a SPohn solid 1 inch chrome moly bar in mine, its not a drag bar but it works damn good.
I ran the 1.43 60ft on a bent stock swaybar, have yet to try this one yet except at the local 600 ft track it bettered its 60 ft by .03 at that track. In much worse air.
Old 10-30-2009, 02:26 PM
BMR Tech's Avatar
Wow that's some body roll....
Our anti roll bar would help immensely in your situation. When the body is moving that drastic it is not allowing the car to plant both tires equally which in turn is hurting your 60' times.
As mentioned by other members we have had great success with our bar.
If you have any questions please feel free to ask
Old 10-30-2009, 02:42 PM
tim99ws6's Avatar
Me: BMR
I used to have some pretty massive body roll as well. I had full suspension with adjustable shocks and everything. I tried the drag-bag thing, but that was a royal PITA.
Installed the BMR drag bar, and even in neutral setting it was damn near level coming out of the hole. Not only does it help 60's, it makes the car much more predictible.
This was me at the LSx shootout in '08. Pretty close to level launch at that point, and a nice SMOOTH transition of power made me look like I almost knew what i was doing, haha:
Thanks BMR!!
Old 10-30-2009, 09:54 PM
BADHAWK51's Avatar
Ok thanks I'm very happy with all the other bmr products on my car k-mem,contol arms.
Originally Posted by tim99ws6
Me: BMR
Thanks BMR!!
Nice pic thanks for the info.
Old 11-05-2009, 03:15 PM
SPEED#1's Avatar
damn you need one for sure and ive seen that car before its sexy as hell, sounds good and moves out
Old 11-05-2009, 08:06 PM
BADHAWK51's Avatar
Thanks man.
Old 11-06-2009, 08:24 AM
JFM-jr's Avatar
Spohn drag/swaybar here. It made a night and day difference the way the car leaves.
Old 11-06-2009, 04:03 PM
BADHAWK51's Avatar
Those are great pics and your car looks perfectly level. Did your sixty drop much if any?
Thanks.
Old 11-06-2009, 04:36 PM
JFM-jr's Avatar
In all fairness I made other changes along with the swaybar that did drop the 60 foot. Car has gone 1.30 and leaves very level with no body twist. The Spohn unit works VERY well. The only drawback to a drag swaybar over an antiroll bar is weight. They are heavy as hell but it's literally right on the rear axle.
Old 11-06-2009, 05:54 PM
Z8'S's Avatar
The TRZ bolt in anti-roll/ panhard combo works great and is also very light. You have seen my car work Jeff so you know.
Old 11-06-2009, 11:56 PM
BADHAWK51's Avatar
Chris your car leaves nice and straight there's no doubt about it.
Quick Reply: Time for a drag bar /sway bar
