Fastest All Time N/A Any Cu. In.
Old 08-16-2010, 06:12 PM
REDGAR's Avatar
Originally Posted by LS1LT1
I take it that you never had a chance to run it all out while shallow staged on Saturday?
I still think there might've been just enough for a 9.999999.
Nope. I thought about it. I wanted it to be on Steve's slip so since he did not have his car, did not try early. I did try first round of Q8 but it was too late and I spun a little..only went .33
Old 08-16-2010, 07:28 PM
LS1LT1's Avatar
Thumbs up
That's alright, another month or so when the air starts to get a little better again it'll happen.
Old 08-17-2010, 12:48 PM
770Guy's Avatar
Camaro
Old 08-17-2010, 12:59 PM
therealthatguy's Avatar
why is it labeled as stock chassis/stock suspension at the top? theres no way these cars are running stock suspension. right?
Old 08-17-2010, 05:14 PM
Firehawk441's Avatar
Stock Style and configuration. Which means maintaining the factory "style" suspension front and rear.
For an example... F-Bodies have upper and lower a-arms in front. A torque arm and two control arms in the rear with a panhard bar. Does NOT have to be OEM parts. Just OEM configuration.
Corvettes and GTO's have independent suspension. If they put a 12 bolt or 9" in the car, Ladder bars, or a 4 link, that eliminates them from stock suspension.
Hope this helps...Rick
Old 08-17-2010, 05:16 PM
Originally Posted by 770Guy
Camaro
Got it. Thanks.
Old 08-19-2010, 02:16 AM
well that makes much more sense, i was about to throw a big *** bs bomb at this thread!
Old 09-04-2010, 11:21 PM
ATVracr's Avatar
8.96 @ 154--460--ATVracr--3100#--Solid--MOZEZ
Old 09-05-2010, 01:15 AM
RUQWIKR's Avatar
9.37 @ 145-- 427in-- RUQWIKR-- 3130#-- Hyd-- LS7
I think it was 144.83...you can put that or 145. My old LQ9-based headed 427 (RIP) had better torque, but, my LS7 runs out the back door better!
Old 09-05-2010, 09:25 AM
Updated... Nice job guys... Bubble is now 9.66 in the top 25.
Old 10-11-2010, 12:01 PM
colemanroddy's Avatar
To Firehawk 441. I Finally got my car running again!!!! After more than a year! New personal best 9.15 at 148. Put my car on a diet 3070 lbs. 430cu.in or a little less. 1 or 2 cu.in. cathedral port heads , hydrolic camshaft, 350 turbo and 12 bolt rear. stock type susp. with no mini tubs. good air about 1200 DA. thanks to trick flow,madman,procell machine,and ptp performance.jeff skinner. thank u guys for hangin in with me. please update for me on fastest list. is there any faster hydrolic cam cars out there????? Coleman Roddy. GOD BLESS
Old 10-13-2010, 01:59 PM
  #32
***UPDATED***
Welcome back Coleman. I was wondering where you've been.
According to the list, you're the fastst N/A hydraulic...
Old 10-18-2010, 01:15 PM
  #33
RUQWIKR's Avatar
Update from PINKS this weekend: 9.27 at 145 with a 1.27 60' on rear tires, DA 1524. Hydraulic LS7 (GM OEM LS7 heads re-CNC'd, GM factory intake, stock bottom end except cam), 3100#. Cam is LPE GT21. A big thanks to Jason Haines and the guys at Lingenfelter! Need a few more hp to keep up with Coleman! Congrats to him!
Old 10-18-2010, 04:59 PM
  #34
**** List is Updated****
Nice job RUQWIKR...
Old 10-18-2010, 05:07 PM
  #35
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
https://ls1tech.com/forums/drag-raci...rd-9-66-a.html
9.66@131-- 346ci-- TSP -- 2865#-- Hyd-- PRC 227 Heads
Thanks!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-18-2010, 06:07 PM
  #36
congrats to yall!!!!!! gr8 pass!!!!! these cars are great!!!!!!!!!
Old 10-18-2010, 06:17 PM
  #37
Thanks!
Got it... Nice job.
Old 10-19-2010, 05:48 PM
  #38
RUQWIKR's Avatar
As in your other thread, appreciate it. Ran 145.83, 144.92, too.
http://www.youtube.com/watch?v=mOLskMnX91I
Old 11-06-2010, 02:57 AM
  #39
Moderator
LIL SS's Avatar
I count as a highbryd.. Little bit off the mark, but hey, there are open spots.. I'll sure it will go faster with the new 418 in it..
3525lbs
Hyd 347ci ported 853's
11.456 @ 118.672
Old 11-06-2010, 06:19 AM
  #40
Race your car!
JL ws-6's Avatar
RayZ06 went 9.11 @ 149, 1.30 60 foot a couple weeka ago at atco. Same car/setup
Quick Reply: Fastest All Time N/A Any Cu. In.
