almost got into the 12's
Old 07-09-2010, 10:49 PM
rokinv8's Avatar
Default almost got into the 12's
i have a 2002 z28 with slp intake and loudmouth exhaust and a set of drag radials. i went to the dragstrip tonight and ran a best run of
60 ft: 2.0082
330 ft: 5.55
1/8 et: 8.75
1/8 mph: 85.75
1/4 et: 13.05
1/4 mph: 107.12
da was 2000 ft. corrected time is 12.7 seconds at 109 mph.
Old 07-09-2010, 10:55 PM
Ph.D. in HUBRIS
custm2500's Avatar
This isn't horse shoes or a **** fight!
Nice time and good luck next time on getting another tenth.
Old 07-10-2010, 01:52 AM
welldonecj7's Avatar
good runs with a little better air you will be there for sure, a4 or m6 car?
Old 07-10-2010, 02:49 AM
meine96ws6's Avatar
Good numbers, but did you mess around with air pressure and maybe a different launch? you should be able to cut that 60' down..
Old 07-10-2010, 04:20 PM
rokinv8's Avatar
the car is an a4 with 3.23 gears. i had the tire pressure set at 23 psi and i was launching at 1500 rpm. i cant get the car to launch any higher than that.
Old 07-10-2010, 06:22 PM
blk/slvr02ss's Avatar
U probally would have hit 12's w/ less air in the tires @ 18psi.
Old 07-10-2010, 09:17 PM
Ph.D. in HUBRIS
custm2500's Avatar
This is the exact thought that went through my head. 1s might cme next time. Just don't plan on them because when you do you will only be let down.
Old 07-12-2010, 11:24 AM
qwk93ta's Avatar
Congrats!! before I had my new motor put in my car ran a best of 13.03 @ 107 with the mods in my sig.
