New Best in Street Trim
Old 11-08-2010, 08:27 AM
1lejohn's Avatar
Default New Best in Street Trim
On Friday night ran a 10.74@ 127 with a 1.64 60'. This was done in full street trim. Thats on 18's all around drag radials in the rear, front sway bar, full tank of gas and hot lapping the car. The weather was decent with just a little moisture in the air and the temps in the 60's.
I'm still having to walk the car out in order to hook it up. On Sunday I installed the rear control arm relocation brackets, and adjusted the rear end. It was off 1/2 inch to one side. With this done I'm hoping the car will start to cut better 60' times. I'm thinking 1.4's. This should put us in the 10.40 range or better.
On a down note the 4.11's will have to go. I'm almost hitting the limiter NA, on spray we will have to shift into over drive. Looks like some 3.73's over the winter. Still don't know what the car weighs, it used to weigh 3460. HRP needs to fix the scales!!
