new best 1/8 et
Old 11-14-2010, 10:00 AM
jtsta02's Avatar
Default new best 1/8 et
first time out since new parts and tune from Ryan at RPM. new parts are nitto nt05r's, pacesetter LT's, 3"ory, magnaflow 3" catback, and stepped the shot up to 125, with ngk br7ef plugs. (02 ws6 m6) 43xxxmiles!
i feel theres more left in it, but i need a rear that will hold! (on stock 10 bolt)
1.65-60ft
7.52-et
94.95-mph
http://www.youtube.com/watch?v=6rhblkWodFI
only got 2 runs cause i didn't have a helmet, 2nd run i was nervous cause the guy came to my window right after my burnout and told me i ran to fast and needed a helmet.
run #2
1.91- 60ft
7.777- et
95.71-mph
http://www.youtube.com/watch?v=2uKXqiyIM8I
Attached Thumbnails new best 1/8 et-time-slips-11-13-10-004.jpg
Old 11-14-2010, 04:50 PM
jtsta02's Avatar
of everyone on this site and no one wants to give there opinion on how i did?? come on post your thoughts, good or bad and let me know where i stand.
Old 11-14-2010, 05:31 PM
Docrocket1967's Avatar
I ran mine for the first time last night and you did better than me my friend. Good job. Sweet video. Faster than most of what I saw last night.
Old 11-15-2010, 08:08 PM
Carter01's Avatar
Research and work on your 60ft, step up to 150 shot and go high 6s.
How is the nitrous being activated? progressive or hitting it out the hole?
Old 11-15-2010, 08:17 PM
jtsta02's Avatar
the nitrous is on a window switch, comes on at 3000 rpm, so pretty much right out of the hole. do u think i can push the 10 bolt harder, i need to safe until i can get a 9"
Old 11-16-2010, 10:48 AM
Dirty Vegas's Avatar
We would need to see a comparison. Did you run it on motor? Any data logging? You should be quicker than that. Full exhaust, bolt on, spray LS1 should be well into the 11's, and you're probably around a 12.0.
Old 11-17-2010, 09:54 PM
jtsta02's Avatar
https://ls1tech.com/forums/drag-raci...ile-times.html
Old 11-17-2010, 10:38 PM
LSxPwrDZ's Avatar
Not bad considering the 10bolt however on the stock 10bolt I was running 7.90's on motor. Put a 9" in it and went a couple 7.10's on a 100 shot and didn't know what I was doing back then and put a 150 in it and only picked up a tenth (too much timing).
When you jug it pull plenty of timing, that 2*/50hp is total BULLSHIT! Most LSx car's I've messed with liked 9-10* pulled for a 150 hit.
Old 11-17-2010, 11:52 PM
I ment this most recent time you went to the track. Trying to compare to 2 months ago after you've installed more mods is useless.
Old 11-20-2010, 09:17 PM
s346k's Avatar
so in a nutshell your bolt-on m6 car went 7.5 @ 95 on a 125 shot?
60' isn't terrible. my bolt-on a4 car went 7.6s @ 88 with a 4k stall, so naturally i think .1 with the addition of 8mph is terrible haha. my 60' was only 1.62...
get a 9" with a real gear in it and give it hell. i think you would easily be knocking on 6s with a clean launch.
Old 11-21-2010, 03:55 PM
jtsta02's Avatar
what was the race weight? i'm at 3700 with me and 1/2 tank of gas.
Old 11-22-2010, 09:34 AM
I'm N/A, at 3300, with the times in the sig. I wanna say my 8th was around a 7.40ish?
Old 11-23-2010, 06:30 PM
s346k's Avatar
my raceweight was 3650.
Old 11-23-2010, 07:00 PM
manfred717's Avatar
Good times, congrats!
Old 11-26-2010, 07:40 PM
krissoto's Avatar
Moving right along. Good job
Old 11-29-2010, 05:22 PM
Omega Doom's Avatar
good job! but what is your car running NA? not too sure the difference between the tracks there and here in TX but i ran a bit quicker NA with no nitrous?
Quick Reply: new best 1/8 et
