cam only 11.1@121 - G5x4
Old 11-16-2010, 01:35 PM
4bangermustang's Avatar
Default cam only 11.1@121 - G5x4
Not sure on raceweight, I would assume 3400+. -300 to -500 DA. Full MWC rear susp, factory front susp. 243 head, unported. fast 90. 4l80e with T0-brake. ford 9" with 3.89.
Well never posted my results. Took the car out on halloween to try and get my 9 second slip with no luck. First pass off the trailer it went:
60: 1.617
1/8: 7.157 @ 97.59
1/4: 11.195 @ 121.50
http://www.youtube.com/watch?v=cSaliFGlD-g
hit it with a single nossle setup 150 shot.
60: 1.494
1/8: 6.616 @ 104.15
1/4: 10.724 @ 104.14 (let out)
Think I might of press the T-Brake button, need to move it to a better spot. So I let out and coasted the rest of the way. Ran rich on this pass. 10.5:1. So we jetted the nitrous pill up some.
http://www.youtube.com/watch?v=EyiPvr4K5MQ
This pass was worse, went 10.9 @ 125 and ran super rich. Thinking something fudged up with my nitrous selanoid. Also poped my TB coolant by pass on that pass so put it on the trailer.
Not too shabby over all. Car still has a few bugs that needed to be worked out. It really needs more gear. The 3.89 with a 2.48 first and 28" tire and killing me. I would prob pick up a good amount on motor going to a 26" tire. Found a few vac leaks when pulling it apart and also logs of the run show my vac pump not adjusted quite right yet. Also could really use some springs and shocks up front.
Car has been making some bad piston slap and did a compression test on it and #6 showed a lot lower numbers. Puleld the heads and all looks ok. #6 does drop like a 1/4" in the hole when I press on it. So either a bearing or something with the skirt.
So new motor setup will be a budget 347 setup with a small tubro.
Old 11-16-2010, 01:44 PM
studderin's Avatar
nice time for cam and LS6 heads
Old 11-16-2010, 02:37 PM
Demonicbird00's Avatar
nice run!
im glad im not the only one whos taken the wing off (its back on now tho)
-brandon
Old 11-16-2010, 03:44 PM
Dirty Vegas's Avatar
Not bad. Can I borrow that cam for a minute?
Old 11-16-2010, 05:09 PM
It's for sale, you should buy it.
Old 11-16-2010, 07:36 PM
studderin's Avatar
what do you guys gain from remove it?
Old 11-16-2010, 09:40 PM
it saves a few pounds.
Only reason mine is removed is I have 2 hatches. 1 has the factory glass and stock wing, the other has lexan and no wing.
Old 11-16-2010, 10:16 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,098 Likes on 721 Posts
Congrats Brian.
I went from 122.5 to 134 on a 150 shot, I'd think you'd be right there.
Old 11-16-2010, 10:25 PM
Congrats Brian.
I went 133 on the ls6 intake and a little more spray on 17" DR's. went 10.77 there with a shity 60' and running out of gear at the top end.
In it's current setup, with a few more tweaks and on a bigger shot I believe it would have gone upper 130's.
I need to talk to you about 347 turbo setups
Old 11-20-2010, 08:34 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Congrats on the N/A #s, but it sounds like you are ready to move on...
Derek
Quick Reply: cam only 11.1@121 - G5x4
