1st time ever racing at the track
Old 11-21-2010, 09:41 PM
s25hanh's Avatar
Default 1st time ever racing at the track
always went with my neighbor down in Gainesville, FL to race his 66 nova. finally switched from my f150 to my camaro. after only 2 weeks of driving my camaro i decided to take it down to the track.
first run nervous as hell, i was about 80% throttle. got a (13.2@105)
best pass i got was 12.9@106 and it was vs a shelby gt600 (yeah 600 haha). lost by half a car link. beat 2 modded mustang gt's big time.
im spinning alot when shifting into 2nd. not as much out of the hole. tires at 15 psi. should of done about 18psi. but my trans was having problems shifting into 3rd at WOT.
Old 11-21-2010, 09:43 PM
baalic's Avatar
Mods?? Not bad for a first run.
Old 11-22-2010, 06:43 PM
Josh@PremierAutosports's Avatar
Congrats man and keep knocking it down. Oh yeah lets the mods begin.
Old 11-23-2010, 08:36 AM
manfred717's Avatar
Nice times, what are the mods?
Old 11-26-2010, 02:57 PM
s25hanh's Avatar
LS1 Forged Bottom End
Forged Connecting Rods
Forged Pistons With HTC Coating
Plasma-Moly Piston Rings
Forged Crankshaft
New Rod Bearings and Main Bearings
LS1 CNC Ported Cylinder Heads
SLP Oil Pump
Double Roller Timing Chain
ARP Wave-Loc Head Stud and Nut Kit
Upgraded Valve Springs
Custom Ground Camshaft, For Forced Induction/Nitrous Setup
Compression Ratio 9:1:1
NGK TR-6 Spark Plugs
TRANSMISSION
4L60E
3500 Stall Converter
Performance Clutches and Steels
Custom Valve Body Work
Boost Valve
Hardened Sun Shell
Trans Go Shift Kit
FUEL SYSTEM
Walboro 255 In Tank Pump
SUSPENSION AND REAR END
Moser 12 Bolt Rear End
3:73 Gear Ratio
Energy Suspension Mount Kit
BMR Lower Control Arms
BMR Weld In Subframe Connectors. (Run almost the entire length of rocker panels)
Carbon Fiber Drive Shaft
BMR Driveshaft Loop
Flow Tech Turbo Exhaust, 4in Outlet
i couldnt get alot of traction. after i get the SLP lid, and mickey thompson ET street's im aiming to get about 12 flat
s25hanh's Avatar
nice avatar haha
Old 12-05-2010, 10:05 PM
s25hanh's Avatar
i should be way faster w/ the full forged motor. maybe its cuz the traction issue. but could it be killing it that bad?
Old 12-06-2010, 05:31 AM
blk/slvr02ss's Avatar
What were your 60ft times ? Your MPH is not that far off from your 1/4 times so there maybe other problems .
Old 12-06-2010, 10:33 PM
s25hanh's Avatar
Old 12-30-2010, 09:03 PM
98_LS1's Avatar
compression is kinda on the low side... needs some type of forced induction w/ that low of a ratio. What kind of tire are you running on?
Old 12-30-2010, 09:07 PM
98_LS1's Avatar
also, was the car ever tuned w/ the listed mods?? which casting heads? specs on cam? Full weight I presume?
something else is not right here... even w/out the traction, it should be trapping more than 106 mph w/ all the listed mods.
Old 12-30-2010, 10:53 PM
s25hanh's Avatar
yeah he had a turbo on it. then took it off cuz it was a bee-otch to tune. tires i ran on it that day were crappy all season highway terrains. the next test and tune ill be running mickey t's ET streets
Old 12-30-2010, 10:58 PM
s25hanh's Avatar
he said the car had been tuned after he took the turbo off but its a crappy tune. idk about heads or spec on cam. i need to find out the specs on cam bad. ik its a custom turbo cam. the rear seats are taken out for good and no spare tire or jack.
thank u for ur help
Old 12-31-2010, 11:53 AM
98_LS1's Avatar
u really need to find out about that tune. does it have a wide band o2 sensor so you could at least know what afr you're running at? I'm just afraid the guy pulled the turbo kit off and either left the tune the same (car would now be running way rich) or just threw a basically stock tune in (car would probably be running lean).
Old 12-31-2010, 03:23 PM
s25hanh's Avatar
okay ill find out about the tune and the duration of the cam and all that good stuff. now if it were running really lean or rich like that, would it mess up the 1/4 mile times that bad??
p.s.---im installing pacesetter LT's in the next couple weeks so im gettin a tune after.
Old 12-31-2010, 03:57 PM
98_LS1's Avatar
having the afr close to optimal for your set-up plays a major role in how it performs! plus, if the afr's are way off, you risk seriously hurting the motor.
Old 12-31-2010, 07:27 PM
s25hanh's Avatar
so basically i need a tune asap? sorry new to lsx's
Old 01-01-2011, 09:06 AM
396D1SS's Avatar
Yeah get a tune asap
Old 01-01-2011, 10:15 AM
fraz's Avatar
A tune with your set up should do wonders.
Old 01-01-2011, 05:04 PM
s25hanh's Avatar
ok thats what i was hoping to hear. should i wait till i get the LT's 1st to get the tune or just do it now?
i really dont want to hurt the motor but nor do i wanna tune it twice in one month. im pretty sure its running rich because of excessive exhaust fumes and soot on the bumper
