First time at track with boltons, doing worse then when I was stock!!
Old 05-11-2011, 06:47 PM
mcalus's Avatar
Default First time at track with boltons, doing worse then when I was stock!!
Full boltons -gears and udp.
Best run out of 6
2.0108 60 ft
9.0429 1/8th
77.99 mph at 1/8th
13.9620 1/4 mile
99.98 mph at 1/4
I'm hooking but I'm boging afterwards...
Suggestions?
Old 05-11-2011, 08:10 PM
jeepers_88's Avatar
slip the clutch a little longer and get a little more aggressive with the throttle. Just dumping the clutch with only bolt ons is going to do anything for you. You just need to get aggessive with the clutch slip and get more seat time. Its an art trying to launch m6 cars, takes lots of practice
Old 05-11-2011, 09:02 PM
s346k's Avatar
what's the da where you are racing?
something is WRONG with that car. 77 mph in the 1/8? what did the car go stock?
i did some "mods", if you can call them that, do the ta. it got much slower, as well, but still did better than that haha.
Old 05-11-2011, 09:59 PM
mcalus's Avatar
Not positive on da, I think it's around 6-700ish.
I'll have to look at my old slips to see what I was running stock
Old 05-12-2011, 02:13 AM
Quick Sh0t xMLx's Avatar
Something is wrong with your car or you're the slowest shifter that this world has ever seen to pull 77/99 MPH with that DA.
Old 05-12-2011, 11:33 AM
mcalus's Avatar
It feels so strong. I don't know what could be wrong with the car...
Old 05-12-2011, 12:16 PM
Xtreme864's Avatar
I was going to say tune but i see you got a mail order. That was my issue, I ran 8.70's in the 1/8th stock, then put full longtube back exhaust on and lid/ported tb etc. and still ran 8.70's and actually ran 8.80s on slicks and couldnt break anything over 83mph. Got a full street/dyno tune and put 3.73's in it (huge upgrade from 2.73's) and she went 8.20's at 84 after touching the limiter. But mine being an auto helps alot at the strip, I know it's alot trickier in a 6 speed.
Old 05-12-2011, 01:37 PM
transamtom's Avatar
I am going to agree with a couple of the other posters...there is something wrong with your car.
Get a Tech2 type scanner and see what she is saying in real time as your driving around.
Don't run it at the strip until you figure it out or it may get expensive.
Old 05-12-2011, 06:08 PM
mcalus's Avatar
Can you elaborate a little on the tech 2? How much is that scanner going to run me? Where can I get one?
Also, would a idle issue put the car in a weird mode?
Old 05-12-2011, 10:04 PM
mcalus's Avatar
I just think it's crazy that something could be possibly wrong when the 3 years I have owned it not a single sign of something wrong. I get decent gas milage, no piston slap on the cold mornings, no odd noises, ... It's weird, I agree, my driving isnt the greatest but 14.0s isn't cutting it for me.
Old 05-13-2011, 10:26 AM
Golf&GM's Avatar
Check the plugs, make sure ALL the wires are snapped on the plugs and not touching the headers, and check the o2 sensors. Be sure all the little normal maintence items are in good shape, too often it's a simple fix. You're seriously down on power though, especially in that DA.
Did any other LS1 f-bodies run up there? Were your times close to theirs?
Old 05-13-2011, 10:39 AM
00ls1z's Avatar
Maybe u just got a Monday built car.. Lol.. Something is def wrong.. Take it to a shop.. Maybe they can find something
Old 05-13-2011, 12:08 PM
mcalus's Avatar
My buddy ran, we both have the same mods, he is A4 but swapped in a set of 3.42s. He was running 12.7s. He is also on drag radials.
I'll have to check plugs and wires since I installed new ones during LT and LS6 intake install.
I'm not going to take my car to a shop and have them "diagnos" it for 100 bucks. I'm going to look into it first.
Would an idle problem make me down on power??
Old 05-13-2011, 04:35 PM
transamtom's Avatar
The Tech2 scanner is the type the dealerships have,snap on also makes one.
You could also use tuning software like HP Tuners, LS1 Edit ect.
You mention an idle problem.
Is it hunting and surging like a vacuum leak?
Check for a vacuum leak with carb cleaner or brake cleaner spraying around possible leak sources with the engine running like the EGR tube on the intake.
If the idle picks up or stabilizes you found your leak.
Check your PCV system,you may be shocked at what you find.
Check the clean air side on the TB for signs of oil.
I would start with all the easy stuff,clean the MAF,TB and change your plugs and wires.
Get some heat shield sleeves from Summit for your wires if you find any melted from the heat.
Old 05-13-2011, 05:59 PM
mcalus's Avatar
I had a bad idle issue just after I put my lts, ory and ls6 intake on. I had to re route the Pcv system because mine fell apart when I was installing those mods. Anywho I got done file line and re routed it. Still had an idle issue. Researched the problem and realized I forgot to install a pcv valve. So I installed it and it idled great. then it started to idle high not nearly as high but not normal
Believe me I have sprayed the whole system down with starting fluid. Intake, pcv system, base of the intake. Torqued intake to spec and in proper sequence.
Plugs and wires are new. If I had a muss wouldn't I notice it? At least in fuel milage? Tb is clean, I have a catch can too.
Could my tune be off? Frost is pretty reputable with his tunes.
Old 05-13-2011, 07:40 PM
transamtom's Avatar
I can only go by my experience but my tune from Frost is spot on.
My car shifts perfectly and runs and drives great.
Your car is way down on power compared to other LS1's with the same mods, something is wrong.
Old 05-13-2011, 07:43 PM
mcalus's Avatar
Obviously, but that isn't solving my situation.
Old 05-14-2011, 08:29 PM
transamtom's Avatar
You cant say I didn't try.
Plus it was a free thread bump to keep it current
Old 05-14-2011, 10:51 PM
mcalus's Avatar
Sorry, wasn't trying to be a dick, just frustrated by the situation
Old 05-14-2011, 11:36 PM
baalic's Avatar
Well bone stock tonight I just ran a 14.5@98 . Welcome to my club..
Quick Reply: First time at track with boltons, doing worse then when I was stock!!
