Does it have more?
Old 05-15-2011, 12:35 PM
SSmoken's Avatar
Default Does it have more?
With the mods in my sig and a 17' mt the car went 11.63 @ 115mph. Cutting a 1.6 on motor. This was the first night I had the car out after the tune.
Old 05-15-2011, 01:01 PM
Omega Doom's Avatar
well according to the MPH i'm gonna guess maybe a bit more?
Old 05-15-2011, 01:47 PM
s346k's Avatar
a head cam car going 115? i'd say there is 5 mph hiding somewhere in there.
as far as with your current results...maybe a tenth or so depending on how well you can get it off the line. with only a 3500 stall and prob 3500+lb raceweight...unknown suspension mods it is hard to tell.
Old 05-15-2011, 02:08 PM
SSmoken's Avatar
Suspension wise it's not really anything. Eibach pro kit and umi adj lca / relocation brackets. It put down 380 on dyno.
Old 05-15-2011, 09:06 PM
chrs1313's Avatar
definitely low on power for only 380 to the wheels...for a el torro and tfs heads...I would have thought at last 120s...unless you are racing in 8000 da conditions
Old 05-15-2011, 09:57 PM
SSmoken's Avatar
I was expecting more on the dynojet, but then figured eh, numbers don't mean everything. I was gonna see what it'd do at the track. That was the cleanest pass I got of the night. I don't know what the da is.
I don't know if maybe my ls6 intake is maybe holding back some hp or what.
Old 05-15-2011, 10:59 PM
ssdeuce74's Avatar
what gears you got, and if the cars is hooking well it will kill a few mph. i have a nova that runs 11.50's at 115mph w/ 1.55 60, you have a bit left in the 60 and i bet even with a dyno tune your likely still lean at the track the ls cars should have a few extra mph but i think your pretty close.
Old 05-15-2011, 11:20 PM
SSmoken's Avatar
its got 3.73's. I will probably take it to test and tune this friday and get a little more seat time and find the best way to launch it and see what it does then.
Old 05-16-2011, 11:41 AM
SSmoken's Avatar
i was trying to figure the DA but couldnt. All i know is the elevation is 1500ft and the temp was 42* at around 1 am sunday morning when i made the pass.
Old 05-16-2011, 04:35 PM
chrs1313's Avatar
http://wahiduddin.net/calc/calc_da.htm
http://www.wunderground.com/
use the history tab to search previous days by the hour
Old 05-16-2011, 05:46 PM
SSmoken's Avatar
Ok I think I did it correctly and came up with a DA of 1921. If that is correct and could possibly effect my et, I still don't know why it only put down 380hp.
Old 05-16-2011, 05:54 PM
ssdeuce74's Avatar
it's not good but it's not terrible either maybe 1-2 tenths max
Old 05-16-2011, 08:08 PM
87silverbullet's Avatar
Was your converter locked? Is there a cutout on the car , if so was it open? Are your heads still as-cast or have you had them worked? There are alot of variables here that could explain your dyno numbers but my car made 382 rwhp on Geoff@EPS dyno and on a hot August day it went 11.83 @115 and I had a 3600 fuddle() 12 bolt 3.73 gears ported 241's TH350 and it weighed 3565 raceweight. 60 ft was 1.68()
Old 05-16-2011, 09:25 PM
SSmoken's Avatar
Locked, no cutout, as cast heads. Was about 85* that day. Maybe I was just hoping for too much thinking it'd make 400.
this is an identical et and 60ft as my car ran on a 100shot before the heads, cam, lt's, and ls6 intake.
Old 05-20-2011, 11:27 AM
You might want to check your stall on the big end and see how much converter slip you are having. My buddy's 99 ws6 ran the same 1/4 time as you but he put down 118 mph with a Vigilante converter with the stock 323 gears. It made 405 on the dyno but I think that was a happy dyno.
Some people have had good results with PTC converters but I haven't had any at all. Burned 2 transmissions and still had a balance problem besides that.
Old 05-20-2011, 04:02 PM
fly pantera's Avatar
with it locked i would expect around 420,how is your intake setup,ls6 intake is not the reason your making 380 locked.
what lid,maf?
brand longtubes?
Old 05-20-2011, 06:16 PM
SSmoken's Avatar
the tuner didnt say anything about converter slip.
what lid,maf?
brand longtubes?
thats alot of hp. id expect that through a 6speed. i dont know if ive seen any autos putting that up but maybe im wrong. all lids are the same, a stock maf is fine, and all longtubes are capable of the same numbers for the most part. Anyway to answer your question its an slp lid and QTP ( which i have in my sig ) longtubes. so im pretty sure neither of those are the reason.
Old 05-21-2011, 06:27 AM
You can lock a converter on the dyno with the tuning equipment the dyno operator is using. Im talking about at the track on the big end.
I understand where you are coming from with the exhaust because I was just like you in my thinking about longtubes until I had to see it with my own eyes. A friend changed out his pacesetters (a header everybody uses) for some ARH's and re-did his TSP y to have a better merge and ended up gaining 18 rwhp. So all longtubes are not the same and I don't think he gained 18 hp from just re-doing the y
Edit: Just found this on the QTP headers and Y https://ls1tech.com/forums/generatio...er-y-pipe.html
Old 05-21-2011, 12:33 PM
that cam camonly should make close to 400rwhp on a locked run.when your cam only no parts are the same,and boltons are fine but some are great.hmm maybe stingy dyno
those headers a good but you can pick up mph by swapping to a ftp lid/85mm maf and get some sort of ram air.
Old 05-21-2011, 12:36 PM
https://ls1tech.com/forums/dynamomet...d-results.html
