First time with ET Streets.
My camaro ran 13.1 on street tires last time at the track. I threw on some ET streets and a ported stock throttle body and went 12.8 both were at 107. I had a 1.9 60ft time launching at 5k. Just a lid, programmer, 4.10s, headers and ory. I tried 4k but it bogged. I was running about 17psi. Do you guys think I could do a little better 60ft or is that about as good as I can do with my set up. Only suspension mods are SFCs and Bilsteins.
having the 4.10's will help. For the most part, the 10 bolt is a weak rear...but on another note there have been guys cutting 60ft times on stick shift for 2 yrs before they broke! crazy stuff. anyways I would try dropping the psi a pound at a time till you hit around 14 and see where it does best. I would bet to see around a 1.70-1.80 60ft about a 11.7 @ 106ish is doable.. good luck bro!
