Fastest 4L60E E.T. "RECORD"
Old 01-08-2012, 09:40 PM
BAMALS1's Avatar
Default Fastest 4L60E E.T. "RECORD"
Just curious to know if there is a list of the fastest E.T.'s or a "record" using a 4L60E under LSX power?
Old 01-08-2012, 11:20 PM
LS1LT1's Avatar
When you say 4L60 do you mean still as a 4 speed (with overdrive etc.) or one of the special 'overdrive removed' (aka: 3L60) type of builds?
Or either one?
Not sure about the whole list but I believe that this guy still holds the overall best:
https://ls1tech.com/forums/canadian-...8-8-160-a.html
Old 01-09-2012, 07:32 AM
BAMALS1's Avatar
Yes, still with a 4 speed and overdrive. No trick stuff like removed gears.
Old 01-09-2012, 07:54 AM
Jeremy@RPMTransmissions's Avatar
There isn't a list that I know of. Arun still has the record with the 8.81@160mph. It is a fully functioning 4 speed 4L60e with a lockup torque converter. We are working on an LSX All Motor class C5 for a customer right now that should drop the record even lower into the 8s.
Old 01-09-2012, 08:11 AM
BAMALS1's Avatar
Nice, that is impressive. Just proves these transmissions are capable. Do you know the specs on the converter?
Thanks!
Old 01-09-2012, 09:12 AM
Thanks!
Yea they are very capable. People don't give them much credit. In built form they can handle a quite a bit of power and run solid numbers. I don't have exact specs on the converter but it is right around 3600rpm.
Old 01-09-2012, 09:23 AM
BAMALS1's Avatar
Thanks for the info I appreciate it. I look to keep mine and see what how fast I can go with it after it's rebuilt. I may just give you guys a call Thanks!
Old 01-09-2012, 09:31 AM
Awesome! Definately give me a call. We have well over a hundred of 4L60e's in the 9s and 10s and quite a few more on the cusp of breaking into the 8s.
Old 01-10-2012, 11:27 AM
TA6spdRDC's Avatar
I have a few vette buddies that should be in the high 8s this year running RPMs 60e One of them is close to the 160 mph mark.
Old 01-10-2012, 07:19 PM
BAMALS1's Avatar
Red face
Damn, that is crazy fast! Looks like RPM is the way to go!
Got any vids of these rides? Would love to see them in action
Old 01-10-2012, 11:02 PM
TA6spdRDC's Avatar
This was Shane on his OLD motor combo.
Old 01-11-2012, 02:20 AM
ittwgn's Avatar
is this for full body cars only!!! i,ll try and find it bit of sure a year or so ago a guy in australia in a cammed ls1 4l60e went low/ mid 8s in a dragster type setup!!! less weight obviously helps!!! well done to all those running good numbers !!could only get mine in the low 10s in a 4050pd car before destroying it!!!gave up and went t400!!!cheers
Old 01-11-2012, 08:32 AM
BAMALS1's Avatar
Awesome! Yea, I was referring to full bodied cars but that dragster sounds cool!
Old 01-11-2012, 08:39 AM
BAMALS1's Avatar
Nice running vettes...did the first one have a Transbrake or just a two step?
Thanks for posting!
Old 01-11-2012, 09:29 AM
TA6spdRDC's Avatar
Thanks for posting!
I have no clue who the blue vette is? Maybe its one of RPMs guys.. As for the red vette im pretty sure it was just on a 2 step.
Old 01-11-2012, 09:37 AM
The blue Z06 is Arun Ahuja (eb02z06). He is leaving off the trans brake and 2 step. Shane is just off the 2 step.
ittwgn I was reading a while back on ls1.com.au about the dragster with the 4L60e but I couldn't find any solid info or videos. You have any links?
Old 01-11-2012, 07:49 PM
BAMALS1's Avatar
The blue is fast but by the way it launched and sounds like it had a 2.73 rear?
Old 01-11-2012, 09:16 PM
Wire guy's Avatar
Anyone know who has the record for the fastest 4L80e with all 4 gears functioning?
Old 01-11-2012, 09:42 PM
BAMALS1's Avatar
Good question, this should get interesting also.
Old 01-11-2012, 10:31 PM
TA6spdRDC's Avatar
mighty mouse has gone 8.50s with an 80e
Quick Reply: Fastest 4L60E E.T. "RECORD"
