Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Results
Sign in using an external account
Register Forgot Password?
Drag Racing Results Track Times | Records | Testing Info
Timeslip Database CLICK HERE
Thread Tools Search this Thread
Old 02-18-2012, 08:01 PM   #1
1999 Chevrolet Camaro
Checkmate's Avatar
Trader Rating: 2
Send a message via AIM to Checkmate
Default 99 ss -
Ran today at MIR.
DA was -750 at the time of the pass, good conditions but not the fall mine shaft air that everyone dreams about, 1st rental of the year but the prep was very good.
My car:
99 SS 6spd with 132k miles. stock internal ls1(still has the ls1 intake and 853 heads), stock shocks and springs, typical bolts ons major one being 9 inch w/4.11, long tubes, hi flow cats through the stock SS cat back, lid, lca, umi tq arm relocated off the trans. And I tuned it off the narrowbands, couldn't get my wideband working at the time. Stock weight.
Et streets @ 17psi cold
Launch was from 4000 rpm (quick release)
pinion angle -2 seemed to yield the least vibration so that is where I left it.
1.80
5.33
8.21 / 84.21
12.77 @ 108.90
I'm pretty happy with the results, I feel it has at least a 12.50 with better driving(still learning the release of the clutch). I'm wondering if I might have better luck lowering the air pressure down to 14 or 15psi.
Thanks,
__________________
99 Camaro SS - red
54 Corvette
Checkmate is offline   Reply With Quote
Old 02-19-2012, 12:07 PM   #2
Garage is empty, add now
GtoSpd's Avatar
Trader Rating: 0
Nice work! Definitely more in the 60'. Is it spinning or bogging much?
__________________
2001 Camaro SS Automatic
Lid, Ported TB, Tune, LM2 Catback
OBX longtubes, ORY, FRA, 3.73s
12.2@114, 7.89@89.5, 1.89 60' (-DA)
Street tires, stock stall
GtoSpd is offline   Reply With Quote
Old 02-19-2012, 02:12 PM   #3
Doug G's Avatar
Trader Rating: 0
MIR open already....damn.
Looked like great air and nice ET
__________________
68 Camaro~406ci SBC(sold motor~ LSx time) AKA:RedЯum
11.304 @ 119.05 ~1320' NEW (3/19/11)...Rules: Are guidelines for the wise and restrictions for the stupid.
11.36 @ 118.xx <---Video
More pics here
Doug G is offline   Reply With Quote
Old 02-19-2012, 03:33 PM   #4
HioSSilver's Avatar
Trader Rating: 5
Send a message via ICQ to HioSSilver
I would say you should be much faster. Your mph is way down......well time should be quicker to. You should be 112+ mph. You may need to practice your driving.
I'm not trying to bust your chops. But with a d/a like that and assuming there is nothing wrong with your car, bottom 12's should be easily attainable.
__________________
'99 SS Camaro #3789 6 speed custom Carbon lid, kooks with o/r y, HS rr, asp pullies, slp 85 mm mass air, tilton 5.5"triple disc clutch, faceplated t56, 3.90's, sealed hood, slot car lca & pahard, mezeir wp, ported fast 90, creative weight reduction
crate ls6 426 rwhp & 405 rwtq 11.15 @ 126.4 1.77 60' on dr's
'03 2500HD ecsb 4x4 6.0, 4:10, locking diff, UPD, desreened maf, 33x12.50 on hummer wheels 16.1@ 86
'05 fz6 11.8 @ 118
'10 Polaris RZR 0-50 6.9 sec
HioSSilver is offline   Reply With Quote
Old 02-19-2012, 04:11 PM   #5
Trader Rating: 2
[QUOTEIs it spinning or bogging much?
__________________
][/quote] what he said,
BOBS99SS is online now   Reply With Quote
Old 02-19-2012, 08:50 PM   #6
ROMERO98Z28's Avatar
Trader Rating: 0
nice run! get the 60' down i think 7.9 in the 1/8
__________________
98 z28 ht stripper lid,ls6 intake,lt,ory,borla.cat-back,umi torque arm,lca brackets,lca,phb,blk 18s adr
ROMERO98Z28 is offline   Reply With Quote
Old 02-20-2012, 12:17 AM   #7
moge11's Avatar
Trader Rating: 0
Youre not driving it hard enough... Launch at 4500 or higher. What RPM are you shifting it at??
__________________
99 NBM Z-28/1SZ M6_ SLP lid_ 8.37@85.26mph 1.95 sixty
1985 Camaro IROC-Z_original SILVER
98 L31 with air-gap and Eddy 750, T-5 - hedman LT's modded w/ 3" X-pipe 3" Dynomax Bullets, Holley Blue pump w/ reg. and guage. electric fan and water pump, S10 steering box, etc....FORSALE make offer.
moge11 is offline   Reply With Quote
Old 02-20-2012, 06:36 AM   #8
Checkmate's Avatar
Trader Rating: 2
Quote:
3000 - bogged
3500 - bogged
4000 - bogged maybe a little on the 12.77 pass
5000 - spun hard
went back to 4000 and it spun again by that point there had been several oil downs and they had just had another one so I packed up and headed home.
Shift light is set for 5900.
I have relocation brackets for the LCA in the lowest hole.
Again, is 17psi to high for ET Streets should I go lower.
Next time out I will get some video and log the passes via hptuners and have a working wideband so I can verify the tune.
With a stock internal motor(again 853 heads and ls1 intake) and my setup what should my 60ft be on ET streets 1.6 or 1.7????
Thanks for the feed back.
__________________
99 Camaro SS - red
54 Corvette
Old 02-20-2012, 11:02 AM   #9
moge11's Avatar
Trader Rating: 0
Well idk what to say.. I guess your shiftin where youre supposed to..
__________________
Old 02-20-2012, 11:23 AM   #10
HioSSilver's Avatar
Trader Rating: 5
You should not be spinning on that et street even @ 5000. My guess is that you need to slip the clutch just a little(do a qiuck release type) and then don't lift your rt foot on the gear changes. My car trapped almost 108 stock and over 109 with only a airlid and a granetelli maf and I was in no where near that kind of air. You just need a little pratice and some double checking on your car.
__________________
'05 fz6 11.8 @ 118
Old 02-20-2012, 02:05 PM   #11
c0ncEpT's Avatar
Trader Rating: 3
Send a message via AIM to c0ncEpT
Is the car stock ride height? If so you might want to try moving the LCA's to the middle hole.
Where is the front TQ arm mount set at for these runs?
BTW I don't think your trap speed is low at all for whats done to the car. 109 with only LT's and a 9" is right on par with what is considered "normal"
__________________
1999 Trans Am A4 | Bolt On's - SOLD
1999 Camaro Z28 A4 | Huron Speed 76mm
c0ncEpT is offline   Reply With Quote
Old 02-20-2012, 03:53 PM   #12
Checkmate's Avatar
Trader Rating: 2
Stock ride height.
UMI suggested the top hole on the relocation braket for the front so that is where it's at for now.
__________________
99 Camaro SS - red
54 Corvette
Old 02-20-2012, 05:24 PM   #13
GtoSpd's Avatar
Trader Rating: 0
Should be able to pull a 1.65-1.70 out of it.
__________________
Old 02-20-2012, 08:08 PM   #14
1999 Pontiac Trans Am
s346k's Avatar
Trader Rating: 3
Good to see youre driving the car and having fun. Id also be looking for more mph. My lid/muffler only 99 car went 87.99 in the 1/8 with a da over 2k'. Im jealous of your 9" and I wont repeat that.
__________________
99 WS6 M6
s346k is offline   Reply With Quote
Old 02-20-2012, 09:20 PM   #15
Trader Rating: 0
Years ago (and 4 different engines) I bought a Moser 9" for my turd gen. It's been hands down the best thing I've ever bought for my car. Tons of hard launches, beat on while street driving, and the best part is you never have that little piece of doubt bothering you everytime you're running the car through the gears.
HeavyMetl is offline   Reply With Quote
Old 02-21-2012, 09:18 AM   #16
Checkmate's Avatar
Trader Rating: 2
Quote:
That's what I was thinking. This was my first time out on ET Streets and 2nd time in 5 years out to the track so I'm getting back into the routine and improvements should come with more practice.
Quote:
I figured with this car I wanted a drivetrain shouldn't break, so I went with the moser 9inch w/wavetrac, monster stg III and the t56 was gone through once and the usual upgrades were done.
95% Street car but when I go to the track I don't want to be the jerk that breaks something and people need to wait an hour before running again.
__________________
99 Camaro SS - red
54 Corvette
Old 02-21-2012, 07:28 PM   #17
GtoSpd's Avatar
Trader Rating: 0
Quote:
n.
No doubt. Update us when you head back out for sure.
__________________
Old 02-21-2012, 09:48 PM   #18
2002 Pontiac Trans Am
z28241's Avatar
Trader Rating: 7
I think those are very good times considering stock internal /LS1 intake and added weight mods.(9 inch rear)
__________________
2002 Trans Am WS6 NBM A4|Street Sweeper Cam|Yank|TSP!|BMR!|UMI!|QA1|Spohn|Strange 12 bolt||ETC ETC.!!N/A!
Tuned by Mike @ New Era Performance
z28241 is offline   Reply With Quote
Old 05-03-2012, 12:59 PM   #19
Checkmate's Avatar
Trader Rating: 2
60 foot is still garbage, 1.87 and 1.89.
Launching from around 4k, 14psi cold.
Driverside axle seal started leaking so I only got 4 passes.
Also, I'm definitely hitting the bumpstops. Was dirty before now a clean spot on either side. Didn't do that at MIR. It certainly looks like its leaving harder than the 60' is yielding.
__________________
99 Camaro SS - red
54 Corvette
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
99, 99ss, camaro, clutch, gears, launching, rating, speed, ss, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
