dissapointing 1/8 mile times. why?? - LS1TECH
Drag Racing Results Track Times | Records | Testing Info
Timeslip Database CLICK HERE
Thread Tools Search this Thread
Old 05-06-2012, 02:25 AM   #1
Default dissapointing 1/8 mile times. why??
Ok, took my 2000 camaro to the track today for the first time ever. My car has 3.73 pacesetter lts, ory, full exhaust system,slp lid stock tune. the temps were in mid 80s with 73% humidity on the first 3 passes. the car ran 9.17 2.31 60ft @80. i made a total of 7 passes and the 60 ft stayed consistent as well as the the et dropped with every pass all the way to 9.28,2.36 60ft@80.6mph. The temps dropped and so did my times?? i had zero spin on any of my passes so thats not an issue. these numbers look normal?? i know it was hot and muggy but i am real dissapointed in these numbers.
possum78 is offline   Reply With Quote
Old 05-06-2012, 03:25 AM   #2
gs462's Avatar
80 mph seems way low, id check the tune make sure its running right.
gs462 is offline   Reply With Quote
Old 05-06-2012, 03:26 AM   #3
jsteele90's Avatar
60 foot sucks and u need a tune . What u expect
jsteele90 is offline   Reply With Quote
Old 05-06-2012, 03:47 AM   #4
Auto or manual?
I thought my car was slow when it ran an 8.8 bone stock...
WhiteKnight '01 is offline   Reply With Quote
Old 05-06-2012, 05:28 AM   #5
Quote:
Originally Posted by WhiteKnight '01 View Post
Auto or manual?
That is kinda slow. I had an lt1 that ran 8.755 stock.
30thanniversaryz is offline   Reply With Quote
Old 05-06-2012, 12:13 PM   #6
Quote:
I know it's slow. But it was also my first time out to the track, and launching from idle.
Old 05-06-2012, 02:20 PM   #7
UsmcAlston's Avatar
What kinda tires are you on? when my car was stock on street tires the best 60 i could manage was 2.3-4s i changed to a 275/40/17 MT ET street and went 1.9s and 8.5s @ 83... is it an a4 or m6... personally i believe a bolt on car will work without a tune those mods you can get away without it... just depends on what your goals are with the car.
UsmcAlston is offline   Reply With Quote
Old 05-07-2012, 12:55 AM   #8
gmantheman's Avatar
It's all in your 60'. Sticky tires will drop your 60' in the 1.7 to 1.9 range and should drop your E.T in the mid to high 8s.
gmantheman is offline   Reply With Quote
Old 05-07-2012, 11:15 AM   #9
JKB315's Avatar
What they said. I went from 8.5s to 7.98 just by dropping my 60ft down to 1.74.
JKB315 is offline   Reply With Quote
Old 05-10-2012, 01:22 PM   #10
GtoSpd's Avatar
That 60' is killing you. If traction wasn't an issue then you should've tried launching harder. Tires make it easier, but you can easily pull 1.8-1.9 60s on street tires if you're on a budget (depending on your track, etc). I have similar mods as you and run 7.9-8.1. That stock tune is definitely holding you back after the launch. You're looking at a half second with a tune.
GtoSpd is offline   Reply With Quote
Old 05-10-2012, 03:52 PM   #11
gs462's Avatar
Quote:
The 60 ft is killing you but it DOES NOT explain the LOW MPH, MPH at the track = horsepower, lack of MPH = LACK OF HP, again check the tune your HP is going somewhere. I see many guys here running the same or close ET but at 85-90 MPH in the 1/8th mile.
Old 05-10-2012, 07:49 PM   #12
GtoSpd's Avatar
Quote:
Exactly....thats why I said the tune is holding him back after the launch.
Old 05-10-2012, 08:37 PM   #13
JKB315's Avatar
Agreed . Even a canned tune would be better than stock. I d send your computer off to frost or a reputable tuner. You ll be happy with the results. My car bone stock with a sld lid and cat delete did 86 mph with a canned tune.
Old 05-10-2012, 10:30 PM   #14
Ok the car is an a4. i could get no spin off the line and was footbraking the car to around 2200 at launch.
Ever since i owned this car it has been a dog off the start. on the street it will barley spin the tires but seems to turn on at 2500, its like you hit the "on" switch. it just has normal street tires. i am wondering if the converter is bad?? i am going to build another motor for this car but want to upgrade the rearend,trans, amd suspension first. would like to see the car run 11.50 so i dont have to cage it to race at the track. For now i just want to see whats up with it leaving the line like someone is pushing it!
Old 05-11-2012, 06:17 AM   #15
GtoSpd's Avatar
Sounds like you have 2.73s. Some 3.73s would make a huge difference. As for foot braking it, I don't use that technique. Mine seems to leave harder if I go from idle.
Old 05-11-2012, 08:58 AM   #16
The car has 3.73 in it alreaady.
Old 05-11-2012, 09:56 AM   #17
RacingTiger03's Avatar
no traction issues with a 3.73 rear and full bolt on LS1..? I want to go to your track lol. All stock at my local 1/8th mile on streets I slip out of the hole and spin the 1-2 everytime... got out of the groove once and lit em up on the 1-2 shift actually.. nice show, no go (10.2 1/8th mile that pass lmao).
On a more serious note, stock stall converter? that would help your 60ft and times, but wouldn't do anything for the MPH... something is going on there, worst MPH I've had in my car was on a hot muggy day like yours, it was 80.78mph with cat-back duals only (no lid no tune nothing else). best mph before was 83.2... but this is an M6 car so there may be a difference there.
RacingTiger03 is offline   Reply With Quote
Old 05-11-2012, 01:53 PM   #18
TravisMcGill2000's Avatar
May be a stupid question but is ur tranny startin in 1st.
TravisMcGill2000 is offline   Reply With Quote
Old 05-11-2012, 05:40 PM   #19
GtoSpd's Avatar
Thats not a stupid question at all^^^ Something is definitely going on....
Old 05-11-2012, 05:56 PM   #20
I ran a 9.1 @ 80.39 my first time taking the car out. Mines a 99, and was stock except for a flowmaster catback that a previous owner had put together at a exhaust shop. I have an A4 with 2.73's, and was running 2.24 60fts. Weather was probably really close to yours. Not sure how you were revving to 2200 without spinning, I was launching closer to 1700 and that was too high, was spinning rather bad off the line.
lagspikeftw is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
My first 10 sec passes ( 150 shot first nitrous passes) floman 10 Second Club 10 09-18-2013 01:41 PM
first time at track 35ss Drag Racing Results 11 08-12-2013 08:46 PM
Ran the Z28 last night. Disappointed and Confused Rare99SS Drag Racing Results 21 04-30-2013 06:55 AM
Stock '99 FRC runs 12.30 at 113.49mph! tpivette Corvette Performance 4 11-27-2012 10:00 PM
My First 12! Took six runs. DevonsZ 12 Second Club 6 07-30-2005 06:51 PM
Tags
02, 18, 2012, a4, bolt, camaro, eighth, line, ls1, mile, mod, stock, time, times, track, trans, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
