11.11 @ 123mph LQ9 Regal
Old 08-08-2012, 01:20 AM
06X6spdGTO's Avatar
Default 11.11 @ 123mph LQ9 Regal
Still have some issue with fuel and I think the carb is too small or the fuel pump cant keep up... Running Pretty lean we were able to come up with a 11.11ET @ 123mph with a 5500DA or so.....
Having some serious traction issues with the MT Et Streets so a swap to some 4.30's is in the works (should pull harder on the big end as well). Best 60' was 1.67 of the T-Brake
Old 08-08-2012, 03:33 PM
sabersaw30's Avatar
Wow that joker pulls hard.looks like it is hooking pretty good.
Old 08-08-2012, 09:55 PM
06X6spdGTO's Avatar
Intial Hook is good if we leave on the 2step at 3400rpm. Once it comes to like it spins pretty hard. weve managed to turn the rim inside the tire @ 8psi about 8inches in one pass.
Im hoping the 4.30's will fix alot of our problems and make it pull harder on the big end.
Quick Reply: 11.11 @ 123mph LQ9 Regal
