Tuned my converter so it locks after the 1/8th :)
Old 09-14-2012, 09:31 AM
98TADRIVER's Avatar
Default Tuned my converter so it locks after the 1/8th :)
I was at Atco last night. Air was decent, nothing crazy (156' above sea level according to drag times) Actually the same conditions as my 11.28 pass a few nights ago.
with the converter unlocked, I trapped 118.44mph
Last night with the converter locking somewhere around 96-101mph, i trapped 120.65mph. Thats a 2mph gain Pretty happy with that.
Video
http://www.youtube.com/watch?v=KC2S5...ature=youtu.be
Old 09-14-2012, 01:21 PM
redtan's Avatar
How and why? I thought the whole point was to unlock the converter at WOT? What does locking it (and at that certain speed) do in terms of speed benefit?
Old 09-14-2012, 03:14 PM
mustangless's Avatar
What converter? Did you happen to get the slip% unlocked? Did it slip any locked?
Old 09-14-2012, 03:22 PM
Golf&GM's Avatar
Nice! Are you running a multi disk?
Old 09-14-2012, 07:41 PM
BAIN's Avatar
Did you pick up any ET?
Old 09-14-2012, 08:42 PM
chrs1313's Avatar
be careful if the clutch is not heavy duty, you will burn through it fast
Old 09-15-2012, 06:03 PM
B18B1LS1's Avatar
Used to do the same with my PT4400 to gain some mph on the top end, took it like a champ.
Old 09-15-2012, 08:02 PM
98TADRIVER's Avatar
Im not going to quote everybody so look for your answers here lol
Circle D Pro stage 1 245mm 4200 stall speed, single disk
Locking the converter (With HP tuners), especially when using a higher stall speed, makes it more effecient up top since there is alot less slip.
I didnt log that pass, but I'll have to check some others and get back to you on the amount of slip, if any, while locked
Its hard to tell what i mightve gained ET wise, as I didnt do back to back runs with it locked/unlocked. I might do that next time just so I can see what the difference is. Definately picked up a solid 2+ mph though
Im gonna make some passes with it next week if the weather's good
Old 09-16-2012, 09:19 PM
chrs1313's Avatar
What method are you using to lock the converter mid pass?
Old 09-16-2012, 11:37 PM
98TADRIVER's Avatar
hp tuners, commanded the apply speed in 3rd gear
TCC max duty cycle is set to 100%
TCC min duty cycle is set to 80-90%
Quick Reply: Tuned my converter so it locks after the 1/8th :)
