8.2 1/8 mile
Old 11-14-2012, 07:57 PM
bigantws6's Avatar
Default 8.2 1/8 mile
Caint seem to get out of 8.2 60ft 1.7 speed is 84 seems to be low on power idk if its my trans is going to give out , tune or tire size my mods are 232/234 .598/.598 112. milled 20 on 241, qtp headers and 4000stall 28 inch drag radial with 3.23 gears
Old 11-14-2012, 08:55 PM
bigantws6's Avatar
Anyone think they might help me with my results
Old 11-14-2012, 10:05 PM
Jackson98Z28's Avatar
I have a similar setup but 26in tire and 3600 stall stock 241 heads and LS1 intake 7.54@91. What's your 60 ft?
Old 11-14-2012, 10:06 PM
Nevermind just saw it...should be running a lot better than that. Is it tuned?
Old 11-14-2012, 10:42 PM
bigantws6's Avatar
Yea street tune don't know how good it is ...yea I know everyone telling me that seems its dwn with pwr I know a few guys say they run that with stall and bolt ons I don't know if its the tire the tuner said might be my trans slipping but don't really seem like its slipping idk maybe because of my loose stall
Old 11-15-2012, 06:10 AM
TORK?'s Avatar
Im gonna say it's the 28" tires and 3.23 gears. Definitely hurting you on an 1/8th mile track.
Old 11-15-2012, 09:53 AM
thunderstruck507's Avatar
trap is bad low IMO, I would expect at least 90mph out of that setup and while the gears/tire size isn't ideal, it is not the bulk of the problem
for comparison my car runs nearly identical times with 3.42 and either 26" or 28" tire, it takes a larger difference in gearing to help much from my experience
the car should be trapping 90mph and running 7.5-7.8 as it sits on a 1.7 60ft unless something is wrong or the weather was way way beyond terrible...and that's based on my experience with a heavy car with crap aerodynamics
scan for codes, clean MAF, check o2 sensors, check plugs/wires, scan for trans slip, and go from there
Old 11-15-2012, 10:58 AM
spicebird98's Avatar
sure sounds like your trans is going...
Old 11-15-2012, 04:24 PM
also check it for spark, could be getting knock retard or have a bad sensor
Mine did and the car ran "normal" (felt slower but you never know when that's in your head) but it was down on trap over 6mph
bigantws6's Avatar
Imma go about changing plugs I have no codes or anything I was leaning toward the tune maybe I should go get it dyno tune what sign do I look for with the trans.... feel okay to me but not forsure
Old 11-15-2012, 04:32 PM
bigantws6's Avatar
Thunder how do I check for spark do I need to hook it up to hp tuner
Old 11-15-2012, 04:44 PM
HP tuners, efi live, or even a Snap On diagnostic scanner
you just want to look at your timing, PCM should be commanding 24-28* WOT and if you are getting any KR (knock retard) then you have a good place to start looking...if it's only a couple degrees you either have bad gas or a poo tune...if you have 6-9* or more being pulled you either have some horrendous fuel, a bad sensor, or whoever tuned it should not be allowed to touch your car again
Old 11-15-2012, 04:56 PM
1Bad97WS-6's Avatar
low on power to me with the low mph. I have an SS4000/Full exhaust/273 gear/275x50 DR/Lid/Free mods/HP tuner an my pb is a 7.53@89.98 with an 1.61 60ft.
Old 11-15-2012, 07:50 PM
bigantws6's Avatar
Lol thunder feel like I'm never gona be taking him my car imma check soon as I get a chance imma do it on a snap on scanner don't have no hp tuner or efi and ill let u know the results @ 1bad yea I know I'm down on pwr makes me frustrated wana sell the car cause it don't run good
Old 11-16-2012, 10:44 AM
I wouldn't be surprised to see that car running 93mph or more once you get it lined out. Just keep at it.
Old 11-16-2012, 01:27 PM
bigantws6's Avatar
Man i hope so just when car ain't running right makes me feel like dam but I gotta to buy my buddy shop to use his snap on scanner to check that ill send u the info on what the timing doing at wot car smells a little rich but is that because I'm runing lt with bullets no cats
Old 11-16-2012, 05:18 PM
z28bert's Avatar
Its because its a race car duh! lol
Old 11-16-2012, 05:36 PM
"MAC"'s Avatar
i ran a 8.484 with a 3600 stall long tube headers lid and a tune forgot my mph but it was like 80-85 mph i also had crappy street tires. With a stall its gonna feel like it slips a little maybe you just need more power to accommodate that big of a stall that you have and you def need to get different gears probably 3:73 should do it, But did you get anything else for your tranni besides the stall? maybe a stage 2 or stage 3 shift kit might help you out as well. I got parts ordered now cam gears lifters valve springs so im hoping ill be in the low 7's( 1/8th mile) once its all finished and the tuner said id should get 380rwhp and 405rwtrq.
Old 11-16-2012, 08:32 PM
bigantws6's Avatar
Albert ain't no dam race car that's ur Mr juice lol and mac no shift stock trans and talk with futral motorsports that sell the cam and he said it should be making 390-400 hp to the wheel
Old 11-18-2012, 03:12 PM
"MAC"'s Avatar
yea well if i was you id get a stage 3 shift kit to help with that stall because thats going to beef it up to help with the power but also to minimize the stress that your stall does on the tranni. The 4L60E that im assuming you have usually breaks down quickly after you do any upgrades to the motor I know mine did so thats why when it did i got a 3600 stall and stage 2 shift kit. Hope this helps out.
Quick Reply: 8.2 1/8 mile
