13.32 at 106.5
Old 05-22-2013, 08:25 AM
01BlueSS1995's Avatar
Default 13.32 at 106.5
Ran a 13.32 at 106.5 by far my best run of the night. Longtubes, Catted 3" Y with DMH Cutouts open, untuned with a bad front 02, Is this a pretty good time considering the circumstances and being untuned? What do you think it will go after a tune?
Old 05-22-2013, 08:30 AM
b.lee's Avatar
on street tires?
Old 05-22-2013, 09:28 AM
Originally Posted by b.lee
on street tires?
Ohhh yeah!
Old 05-22-2013, 09:54 AM
HCI2000SS's Avatar
Might pick up 1-3 mph with a tune
Old 05-22-2013, 10:42 AM
Lawhead's Avatar
12.93 at 109 here on street tires and a M6 Lid/Catback
Leaving a lot on the table I would think
Old 05-22-2013, 12:09 PM
LS1rob00's Avatar
02's don't affect wide open throttle.
What was your 60'? A4 or M6? Street tires are hurting you and so is not having a tune. Seems like something is up though. My car did 111-112 with no tune and those mods.
Is all the maintenance up to par on the car? Speak plugs, air filter, fuel filter, oil etc?
Post the slip up so we can see the whole story.
Old 05-22-2013, 12:11 PM
b.lee's Avatar
Originally Posted by 01BlueSS1995
Ohhh yeah!
What was your 60ft time?
Old 05-22-2013, 12:32 PM
redbird555's Avatar
Yes they do over time if the o2s are bad they will distort the fuel trims and this will be seen at wot. The o2s shut off basically at wot but the fuel maps they created over the days prior are what's used at wot.
I agree that trap is slow with a. Tune it should be doing 112
Old 05-22-2013, 04:46 PM
1BAD98LS1's Avatar
The car should dip down in the 12's very easily after a tune... mph is questionable depending on trans and launch
Old 05-24-2013, 08:57 PM
LS1again's Avatar
Im around the same ET but faster traps in a 2000 Z28, so I have the shitty LS1 intake, and I don't have LT's or ORY yet. Something seems off, maybe it's the LT's making it run not up to par without a tune? What was the 60's and any idea of your DA? You can check here to figure it out...
http://www.dragtimes.com/da-density-...calculator.php
Quick Reply: 13.32 at 106.5
