First track outing
Old 07-06-2013, 02:24 PM
021le's Avatar
Default First track outing
Here are the current mods.
Yank 4000 RPM stall converter
233/236 custom cam
tune
Hooker long tube headers
Underdrive crank pulley
MSD wires
egr/air delete
Optima red top battery
Intake lid with K&N air filter
Lanes true dual 3in exhaust with twister mufflers
Dr. Gas X pipe
Auburn locking rear end with 4:10 Richmond gears
Eibach 2 in. lowering springs
QA1 shocks
Drag bags in rear springs
Frame connectors
Baer Eradispeed rotors
18" Hitchcock Full House C5 wheels with 295/35/18 BFGoodrich drag radials.
best time.
1.79 60ft
7.81 1/8th
89.14 mph
12.14 et
112.50 mph
temp 82, da 2318, rd 93.39
car was hot lapped, too very little cool down.
This was my first time to the track with this car. 295/35/18 bfg drag radial tires at 20psi.
and tips?
what times can I get out of it? hoping for an 11.80
Old 07-07-2013, 10:45 AM
021le's Avatar
anyone?
Old 07-07-2013, 04:25 PM
BODUKE's Avatar
I'm not a fan of tall rims and tires. I've cut 1.6 60fts on 16 inch nitto tires. You will run better times in the fall.
Old 07-07-2013, 05:35 PM
floman's Avatar
If you could manage to get the 60ft time down another 1/10th you would be breaking into the 11.9x range just from that improvement. Maybe experiment with different launch techniques ( raise or lower your footbrake rpms on launch and see what the converter likes). Try to let the car cool down between runs and you will probably gain slightly also. Your trap speed is close also, usually around 113 mph gets you into high 11s.
As "BODUKE"" said, in the cooler fall air you will be close to your goal.
Good luck!
Old 07-07-2013, 09:22 PM
021le's Avatar
thanks for the replys.
new to these cars, just seeing if my times are good for the mods
I have
Old 07-08-2013, 10:47 AM
moge11's Avatar
What are your shift points??? Has it been on the dyno??
Old 07-09-2013, 09:14 PM
Tenured Member
Timmy2Stage's Avatar
Looks right on the mark for what is done to it. The 60ft is holding you back. With that converter your car has the ability to cut a low 1.5X short time. A 15" rim with some ET Radials on it will help you get there. Also, being 2" lowered is not helping at all.
1) Change your rear rim/tire setup for the track and even in that air you'll go 11.9X.
2) In addition to the tires, better air you'll be clicking off 11.7-11.8's all day long.
Old 07-10-2013, 06:18 PM
021le's Avatar
thanks, just seeing if I am at the "norm" for the mods I have.
Old 07-14-2013, 12:52 PM
021le's Avatar
Second time to track
best time.
1.76 60ft
7.61 1/8th
91.76 mph
11.82 et
116.01 mph
temp 84, da 2458, relative density 93%
getting faster
Quick Reply: First track outing
